drag times
Postby slowdiesel » Sun Aug 23, 2009 7:31 am
fatty wrote:
slowdiesel wrote:12.43
what have you got for mods this time
same mod's just track was prepped this time, It usually breaks traction when the second charger hits, But just a little.
1984 D100 Ve-Twins.
Special Thanks Mayer Farm Equipment
slowdiesel
Postby soggy » Sun Aug 23, 2009 9:21 pm
92 W250 VE Powered
13.31@ 98.92
1993 D350 Tow Rig
soggy
Postby BC847 » Thu Sep 03, 2009 8:50 pm
Just made my first pass with the new cam and IC. 8.36 @ 80.43 in the 8th. :D
Still got to tune it some.
I may try to get a pass at a 1/4 mile track this weekend. 8)
Postby fatty » Fri Sep 04, 2009 10:21 am
BC847 wrote:Just made my first pass with the new cam and IC. 8.36 @ 80.43 in the 8th. :D
Very nice. Is that an auto or manual?
Postby BC847 » Fri Sep 04, 2009 10:27 am
It's the factory original A518 with a Suncoast non lock-up converter. I've "Laid Hands On" the innards. ;)
R/T = .0961
60' = 1.8485
330' = 5.3446
1/8th = 8.3697 @ 80.43mph
Postby BC847 » Fri Sep 04, 2009 10:44 pm
Cancel my last. :o
Went to Coastal Plains Dragway (1/4) tonight.
#95
Still tuning. 8)
Postby GLHS » Sat Sep 05, 2009 4:03 pm
Good job!
Getting very close to dem dare 12s.
Think the intercooler helped?
GLHS
Postby soggy » Sat Sep 05, 2009 6:25 pm
Very nice, so are you still running W/M? Or are you going to be the first to crack the 12s on fuel only?
92 W250 VE Powered
13.31@ 98.92
1993 D350 Tow Rig
soggy
Postby crewcabxlt » Sat Sep 05, 2009 7:46 pm
wow! nice 1/4 bc
78 ford crewcab,90 6bt,120k,pods,hx-35-12,ported parts.pump mods,3rd gen intercooler.dyno @298rwhp,808 tq uncorrected @4800 ft,dyno june 09 w/he-351turbo,364 rwhp-tq?,3 other 1st gens on the farm.
crewcabxlt
Postby slowdiesel » Sun Sep 06, 2009 6:18 am
I will turn the water off and see if mine gets in the 12's fuel only.
1984 D100 Ve-Twins.
slowdiesel
Postby BC847 » Sun Sep 06, 2009 9:47 am
GLHS wrote:Think the intercooler helped?
It's hard to say as the apparent results are muddied by the new cam.
My point in adding the cam & IC was to better utilize the excess fuel from the new 6x'016" EDMs.
In that regard, it seems to have worked. 8)
soggy wrote:Very nice, so are you still running W/M? Or are you going to be the first to crack the 12s on fuel only?
Yup, still running W/M FWIW.
NOTE: I've not done anything with the W/M since running the single HX35 hybrid. Still running a single 220psig pump (regulator maxed) with two of the .625 Snow nozzles. I really need to add another if not a single bigger pump in order to have the correct minimum operating pressure at the nozzles (with now running around 55psig boost) so they spray correctly at WOT/full boost.
Anyhoot, as such, the last time the heap went on a dyno, the W/M was only good for an additional 60ft/lbs and 0HP.
With the recent cam and IC swap, I finally got around to putting the W/M controller on the boost-fooler that feeds the AFC. The boost-fooler is set for a 2/1 ratio meaning with say 40lbs boost, the AFC & W/M controller sees only 20psig (The W/M controller is setup for up to 35psig boost control-wise). The point of the boost-fooler is to place the AFC and W/M back into their designed operating range (boost-wise).
Some excuse huh? :lol:
Re: drag times
Postby Hansen01 » Sat May 19, 2012 12:15 pm
Ran down the track last night in the 1/8 mile in 10.935.
I think i could do better but it was my first time 8) overall i was pleased :D
I will get my time slip posted a little later
http://www.facebook.com/#!/photo.php?v=10150795894192587&set=vb.506697586&type=2&theater
Under construction...
Hansen01
Re: drag times
Postby dazedandconfused » Sat May 19, 2012 1:02 pm
Think didnt work.
Re: drag times
Postby Hansen01 » Sat May 19, 2012 7:45 pm
Hmm, i dunno how to get the video from facebook to Photobucket :?
Hansen01
Re: drag times
Postby BC847 » Sat May 19, 2012 9:21 pm
The link works for me. ?
Return to Competition
