Hello all,
Im new to this site..
Im currently running a 2002 Ford F350 7.3L all done out with 450 RWHP...
I have decided to move on and am on the hunt for a new truck.. I am going tomorrow to look at a 1990 2wd dually automatic... Chances are this engine will get built and end up un a crew cab...
So I need some help... Im a newer cummins guy, so please smack me if I ask dumb questions!!!
I want the truck to be just as fast as my 7.3L was....
So, seems common to change to a 3200 spring, Denny T pin, 2 turns on the fuel screw, 3 on the smoke screw and adjust idle...
Before going too much farther please understand that the basics will be covered.. This turck will have gauges, good TC, shift kit, intake, 4" exhaust.. all the stuff every diesel should have...
Next... I know this is a non IC truck... I plan on adding an IC when I do the fuel mods listed above...
here is where I need a little help... being new I dont know exactly what is needed..
Injectors: PODs? too smoky??
Pump: Brian Block 14mm head... can I tow with this? Sounds like not?
Fuel system.. Sounds like an electric pump is in my future? is there one better than another?? Im running a full custom system on my PSD with a fass pump and donaldson filter...???
Turbo(s) ????? Im new to cummins turbos...
Head studs.. forgot this on my list above...
Looking for like 500-550... streetable... towable...
Please help me... Im all ears!!!
