do i need to up do the battery
Postby james-93-12valve » Tue Sep 01, 2009 11:16 pm
do i need to undo the battery on my truck if im going to weld on it
93 d350 5spd 4inch exhaust to a 6inch tip pump tweaked
james-93-12valve
Postby peobryant » Wed Sep 02, 2009 12:05 am
You don't "have" to, but I would recommend it. A lot of people have gotten away with not doing it, but then again, a lot of people haven't gotten away with it.
I would do it, cheap assurance.
Postby Richie O » Wed Sep 02, 2009 3:05 pm
Go ahead and unhook it. I never do but I am careful where my ground is.
Postby james-93-12valve » Wed Sep 02, 2009 10:36 pm
Richie O wrote:Go ahead and unhook it. I never do but I am careful where my ground is.
what do you mean your careful where your ground is and wat does it do if you dont un do your baterry
james-93-12valve
Postby burnt_servo » Thu Sep 03, 2009 1:05 am
while i can't speak for richie o .......
careful use of your ground would include , if your welding on a quarter panel , the ground is on the quarter panel , NOT on the frame , forcing the electricty through the grounding wires from the body to the frame .... and vice versa
other things that this would include , when welding on lets say a axle tube , you position the ground so the current won't bass through any bearings , possibly fusing the bearings together .
in other words keep the ground in very close proximity , and on the same piece being welded , and you should be fine
'93 w250 .... stock ...
burnt_servo
Postby james-93-12valve » Thu Sep 03, 2009 11:58 am
ok i was told that it would mess the computer and the battery is that true
james-93-12valve
Postby SOOT4BRAINS » Thu Sep 03, 2009 12:49 pm
Electricity takes the path of least resistance. If that path happens to be through a battery or computer or wires etc, it definitely has potential hurt stuff.
93 D250 Rag 3.54, 4 inch stans downpipe to custom 4 in exhaust, pump cranked with m3 pin, 366 spring, tach,boost,pyro,fuel pressure, ddp 70lpm sticks, 62/65/12 s300, airdog 150, rebuilt getrag, 3250 SBC clutch, helix 2 camshaft, dual redtops, new paint.
SOOT4BRAINS
Postby burnt_servo » Thu Sep 03, 2009 1:04 pm
james-93-12valve wrote:ok i was told that it would mess the computer and the battery is that true
if your worried about it , just pop off the postive terminal .
burnt_servo
Postby Richie O » Thu Sep 03, 2009 2:22 pm
You hit my point just fine, And saved me some typing. :D
Postby PToombs » Thu Sep 03, 2009 5:44 pm
I also grind clean the spot the ground is going onfor a better connection. I never used to unhook the battery to weld. But since I welded on an excavator at work and a week later the PCM went bad, I unhook the battery, computers, throttle activation motors and such.
I can't afford a $2300 computer! ;)
Return to Electrical
