Twins and 47RH
Postby 90FIRSTGEN CUMMINS » Thu Sep 10, 2009 10:47 am
Thanks alot those sites have about all the stuff I need. Its great having you guys to help me along with this stuff. Im looking for a waste gate actuator for a b1 does anyone know what one may cost and where to get one.
1990 W250 Non I/C, Mostly stock,4 inch Ex,Fuel Screw Turned Up a Little, 727TF, 366 spring, BHAF, Borgeson Steering Shaft, Under-bed B & M transmission cooler, head lights now on relays(just added)
90FIRSTGEN CUMMINS
Postby 90FIRSTGEN CUMMINS » Fri Sep 11, 2009 5:47 pm
Should be picking up a 47 rh soon. Has anyone delt with Brian Vanest.
90FIRSTGEN CUMMINS
Postby AHineman » Fri Sep 11, 2009 6:08 pm
He rebuilt the 727 in my 90. I also know alot of other people he's done work for. Around here he's the man when it comes to dodge transmissions. I've been very happy with his work.
Postby PToombs » Fri Sep 11, 2009 7:30 pm
Where is he located?
Postby AHineman » Sat Sep 12, 2009 1:15 pm
Ravenswood West Virginia.
Postby 90FIRSTGEN CUMMINS » Mon Sep 14, 2009 8:56 am
Ok thanks for the Info. I think i am going to have him do a 47RH with lockup in all the gears plus overdrive on a switch.
90FIRSTGEN CUMMINS
Postby 90FIRSTGEN CUMMINS » Tue Sep 15, 2009 1:41 pm
I just talked to Brian and he is real knowledgable and has really good prices. His price on the conversion was real good too. Now I just have to wait fo the guy to get the 47rh out of his truck so I can buy it.
90FIRSTGEN CUMMINS
Postby 95ram » Mon Sep 21, 2009 8:49 am
Try airflo.com for the tubing. That's where I got mine from for the last set of 2nd gen twins I did.
95ram
