another turbo question
Postby TTipswprd » Wed Sep 09, 2009 7:59 pm
another turbo question. i can pick up an hx35 for about 350. is that upgrade worth the money?
1992 w250 4x4, pump tuned, custom exhaust, intake, and dennyT fuel pin, cooler tubz, 5x.014's from SDX
TTipswprd
Postby pulltilbroke » Wed Sep 09, 2009 8:02 pm
I'm gonna say no, just keep savin and get a real turbo
Postby TTipswprd » Wed Sep 09, 2009 8:06 pm
ive learned a little more about turbos now! i hear the 12cm exhaust housing can ride a little hot while towing. do i need to look for a turbo with a 14 or 16cm housing? will an upgraded turbo wiith a largewr housing still spool quicker than the stock turbo and still keep it cool?
TTipswprd
Postby Oddfire » Thu Sep 10, 2009 12:01 pm
$350 is to much. But, for a little less the HX35W is a fun little charger for a truck with mild mods. 8) I loved mine, but never had temp problems because my factory lp cant keep up with my injectors. :;-|:
Oddfire
Postby crewcabxlt » Thu Sep 10, 2009 1:36 pm
hx-35 is a pretty good turbo for $200-$250. 12 cm is a great housing for towing or whatever, overspooling the turbo out of its efficiency map is what raises egts. hx 35 has a mwe slot wich helps too. keep boost in 30-35 psi its great.
78 ford crewcab,90 6bt,120k,pods,hx-35-12,ported parts.pump mods,3rd gen intercooler.dyno @298rwhp,808 tq uncorrected @4800 ft,dyno june 09 w/he-351turbo,364 rwhp-tq?,3 other 1st gens on the farm.
crewcabxlt
Postby peobryant » Thu Sep 10, 2009 8:19 pm
If you had a Non I/C truck, an HX35 would be an okay upgrade, but since your I/C H1C is just about as big as an HX35, I would pass an HX35 up, unless you found a screamin' deal on one, or for some reason your H1C needs to be replaced.
The 12cm housing is perfectly fine for towing. They came stock on 2nd Gen trucks, so they won't get too hot (with reasonable fueling :D )
Postby TTipswprd » Thu Sep 10, 2009 10:02 pm
ha ha pump maxed and injectors resonable?
TTipswprd
