435's and timing
435's and timing
Postby SOOT4BRAINS » Fri Sep 11, 2009 8:53 pm
Ok so my friend came over today and we advanced his timing a tooth. (same guy who has the goerend converter that I posted about before) We also got a metric dial indicator and the adapters to check the timing. It is too far advanced now, we need to back it off but we ran out of time to put the timing tool on it to see where it really is. Here is his sig from DTR so you can see his mods.
1993 w-250 4x4 dual 6'' mitre cut stacks,4 inch dp,Bhaf, ATS Manifold, 435 injectors,62/65/12, new ve pump(tweaked), new A518 trans,Gorend TC, 3200 gov. spring, Raptor 100 eletric pump,AFC lever gone, Isspro Gauges, tach, pyro, boost,tranny, fuel pressure, custom 5 pillar gauge holder
What do you guys think would be a good starting point for setting his timing?
93 D250 Rag 3.54, 4 inch stans downpipe to custom 4 in exhaust, pump cranked with m3 pin, 366 spring, tach,boost,pyro,fuel pressure, ddp 70lpm sticks, 62/65/12 s300, airdog 150, rebuilt getrag, 3250 SBC clutch, helix 2 camshaft, dual redtops, new paint.
SOOT4BRAINS
Postby Begle1 » Fri Sep 11, 2009 9:14 pm
Timing is really not a precision operation by the time the engine is molested to that degree...
If the truck's heavy, start with an 1/8" bump. If the truck's a toy, start with the pump to the head. If the truck's a toy with head studs, jump a tooth and go from there.
When it sounds really sharp under acceleration but doesn't pulse or shudder, you got it set good. :lol:
Postby SOOT4BRAINS » Fri Sep 11, 2009 9:49 pm
I should have elaborated a little more :D . The tranny shifts at 23-2400 rpm under full acceleration. We put some springs in the valve body to prolong the shifts and it made low to mid rpm shifting much better, but it still shifts early going full bore. If you hold it in gear manually it feels like its kinda tapering off on top end and I think the tranny is seeing the power taper off and shifts. We already had the timing to the head. Others on DTR have told him that 435's like a lot of timing. He thinks he should be getting more power with these injectors and he has been nagging me daily to help him jump a tooth so we did it today. So now its really advanced.... still sounds ok, a little more "crack" to it, but not bad, no goofy sounds. But now it has 10 psi less boost and is a dog compared to before. So we are going to back it off tomorrow and slap the timing tool on there. Any body know how many mm's a 1/8 inch bump is roughly? How far is too far without having head studs? I know advancing timing will increase your cylinder pressure without nessecarily increasing your boost. 40 psi with a lot of timing could be as bad as 50 psi of boost with normal timing. Either way you can blow a head gasket. Thanks for the input Begle!
SOOT4BRAINS
Postby Begle1 » Fri Sep 11, 2009 10:09 pm
Spend a night at the dragstrip moving it around until you get it in the sweet spot.
1/8" is about 3 millimeters, which is about three degrees.
Postby SOOT4BRAINS » Fri Sep 11, 2009 10:24 pm
I meant to say mm's of plunger lift as measured with the timing tool. Thanks for the help, I think a trip to the drags is in the near future. If we do that, I'm definitely going to get a special wrenchs to reach the pump bolts. We do it with a crows foot and an extension....... by the time you adjust it and get it all tightened back up, you are so frustrated you swear you will never touch it again :lol:
SOOT4BRAINS
Postby Begle1 » Fri Sep 11, 2009 10:31 pm
Oh yeah, the millimeters=degrees thing pertains to plunger measurement and not the timing mark measurement... :oops:
I have yet to understand the whole plunger measuring concept... Just do it by ear and feel...
Postby SOOT4BRAINS » Fri Sep 11, 2009 10:43 pm
I dont fully understand it either, hopefully after tomorrow I'll have a better idea. Going by sound and feel has worked fine for me on my truck. I figured that seeing as how he can hit 45 psi and has no studs he should just leave the thing alone and be happy with my "sound and feel" tuning, but he paid for the timing tool so what the heck. Maybe I'll learn some thing by messing with it. Before we jumped a tooth I thought the truck runs pretty good. Spools pretty quick and just plants you in the seat till you tell it to stop. I won't race him any more :lol: I can't shift that fast.
SOOT4BRAINS
That "S" wrench
Postby ZSkibo » Sat Sep 12, 2009 6:47 am
was one of the best investments in special tools I ever made.
92 W250 Pump bombed, AFC out, 366 spring, 18* timing, KSB hotwired, HX35 12cm non wg, New Era 6x18's, BHAF, 60 lb in/ex springs, 4" PAC Brake, onboard air, Nathan P3 horns
ZSkibo
Postby bgilbert » Sat Sep 12, 2009 7:42 am
Begle1 wrote:I have yet to understand the whole plunger measuring concept... Just do it by ear and feel...
Agreed. 556hp so far without the tool.
Bill Gilbert
Postby matchew » Sat Sep 12, 2009 7:00 pm
Soot...who is it? I'd still like to meet up with you guys some time.
92 1 ton, 7" lift 37 military MT's on Hummer Alcoas, HE341, 4" downpipe to tailpipe, killer front bumper, 14mm H+R, +40 injectors, 03 dodge seats, loud tunes. 'Custom' Rustoleum paint.
matchew
Postby SOOT4BRAINS » Sat Sep 12, 2009 8:23 pm
Matchew, he goes by SMKHZRD on DTR. We got it all done today, we adjusted the timing, and put AFC lever back in. The timing was way far advanced, which we knew, I set it at 1.9mm and called it good. Before all this the turbo would spool to about 40 psi and creep to 45 above 65-70 mph. Now it spools to 42 psi and creeps to 45 psi above 65-70. He said it feels like it spools a little slower, but its cus the afc lever is back in. Once it starts spooling it pulls a little harder. Tranny still shifts in the same spot. I told him if his shift points are that much of a problem just he should have got a 5 speed :lol: :lol: :lol: You have to pull the injector lines off the pump to get the tool in there, kinda a pain. Two tools I really need to get are the pump bolt wrench and an engine barring tool. Those would have saved us some time and made it easier. I still think sound and feel works ok, but the tool is nice to have if you want to fine tune it and know where its at. Thanks for the input guys!
SOOT4BRAINS
I've got the barring tool too!
Postby ZSkibo » Tue Sep 22, 2009 6:27 pm
Yay me! No but really, I bought that one too and it make's doing a vlave job so much easier. Paid for itself in time the first time I ever used it.
ZSkibo
Postby fatty » Tue Sep 22, 2009 9:11 pm
you could be at 600 with it :D
