RPM with 14mm pump
RPM with 14mm pump
Postby JQmile » Wed Sep 16, 2009 12:32 pm
What kind of RPM you 14mm guys turning? 3200 spring?
JQmile
Postby RSWORDS » Wed Sep 16, 2009 2:49 pm
oh so NOW your gonna worry about tearing up the truck!!! :lol:
RSWORDS
Postby JAyers » Wed Sep 16, 2009 5:54 pm
Ive turned mine to 4k a few times but I dont have the 3200rpm spring.
93 W250...balanced, ported, and fresh. Equipped with 14mm h/r, A1000 supply, Hamitons 188/220, T4 stainless manifold, s360/68/.91ar - s475/74/1.1ar twins, and Kennys dd clutch.
JAyers
Postby swank » Wed Sep 16, 2009 8:22 pm
All I'm going to say is that they (my KTA at least) seem to handle high rpm just fine.
truck
swank
Postby JQmile » Wed Sep 16, 2009 8:46 pm
RSWORDS wrote:oh so NOW your gonna worry about tearing up the truck!!! :lol:
Hey I'm looking at moving again, my truck might actually get some non-burnout use :D
JQmile
Postby peobryant » Wed Sep 16, 2009 8:48 pm
It would make one mean little drag truck, if it could hook up of course.
Postby fergavs » Wed Sep 16, 2009 10:13 pm
I've spun mine up to 3500rpm or so. It seems to like it just fine.
fergavs
Postby seeker1056 » Thu Sep 17, 2009 11:22 am
mine has been to 4700 rpm in first gear twice while pulling
usually run first to 3800 rpm and it carries 35-3600 rpm in second gear
it definitely doesnt like the higher rpms as we did find it did gall some pieces inside when we were checking out timing piston issues
Sponsors of new truck
Performance Diesel Injection
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
Postby matchew » Mon Sep 21, 2009 5:11 am
When I got mine built, the pump shop set it to de-fuel(?) at 3700 rpm. The truck really sings now! Still need to further upgrade the fuel system though...I can feel it fall off as the LP looses pressure. Gotta be careful!
92 1 ton, 7" lift 37 military MT's on Hummer Alcoas, HE341, 4" downpipe to tailpipe, killer front bumper, 14mm H+R, +40 injectors, 03 dodge seats, loud tunes. 'Custom' Rustoleum paint.
matchew
Postby seandonato73 » Sun Oct 25, 2009 6:42 pm
are you guys running the 4mm cam plate too?? and how did you get your truck to spin past 3200???
90 dodge w250, 4" turbo back exhaust, 80hp ddp injectors, 3200rpm gov spring, fass punp, custom intercooler, injector pump maxed out, reground fuel pin, south bend clutch
seandonato73
Postby seeker1056 » Mon Oct 26, 2009 5:39 am
spin past 3200? lol - easy stick yur foot in it, lol - easy that is when you have a larger governor spring (4200) in it that is.
Actually a properly set up pump with a 3200 spring in it will run to about 3400 rpm before it falls off
My 4200 spring would run to 4700 rpm
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
Postby seandonato73 » Mon Oct 26, 2009 8:48 pm
thanx :D
seandonato73
