Pulsing Brakes
Postby TTipswprd » Mon Sep 21, 2009 11:53 am
ya it sounds like a hissing sound when i step on the brakes and if im hard on em then my truck pulls to the right.
1992 w250 4x4, pump tuned, custom exhaust, intake, and dennyT fuel pin, cooler tubz, 5x.014's from SDX
TTipswprd
Postby cougar » Mon Sep 21, 2009 1:53 pm
PToombs wrote:TT, most likely the ABS valve. I'd vote that over the master cylinder. BTDT. ;)
If the dump valve is leaking, the you probably could pump it up. If the dump valve is stuck open , then you would have mushy brakes all the time.
If you are hearing a hissing sound, then the booster is possibly leaking. Pulling can be an out of adjustment brake or contaminated linings.
01 2500 "the work truck".
cougar
Postby TTipswprd » Mon Sep 21, 2009 3:32 pm
so can i fix the leak or do i need a new booster?
TTipswprd
Postby cougar » Tue Sep 22, 2009 8:58 am
The booster is not repairable. A leak check can be performed to verify a problem. Using a hand vacuum pump. see if the booster will hold vacuum. They say no more than 1"hg drop in 15 seconds is OK.
cougar
