New 2wd lift kit?
New 2wd lift kit?
Postby darestie » Mon Sep 28, 2009 9:42 am
1993 D250, 5speed. starwheel turned, ASA Intake, M&H M3 fuel pin
darestie
Postby rattlebox93 » Wed Oct 21, 2009 9:30 pm
did you try em? i think im going to get a set
rattlebox93
Postby darestie » Sat Oct 24, 2009 3:36 am
no, I had to get tires first. post back if they work.
darestie
