vacuum pump ?
vacuum pump ?
Postby txs » Thu Oct 08, 2009 11:36 am
Will the vacuum pump come off and the power steering pump then bolt back to the rear of the timing gear case or do you have to find a stand alone power steering pump?
txs
Postby Philip » Thu Oct 08, 2009 4:35 pm
The pump will not bolt to the gear case. There is a mounting assy that goes between the power steering pump and the gear case.
