N/IC vs IC pistons
N/IC vs IC pistons
Postby Remps » Thu Oct 08, 2009 4:55 pm
I am wondering if the wider N/IC piston bowl is more tolerant to advanced timing,by that I mean the injector spray pattern staying in the piston bowl better than a I/C piston?Any differences in durability or "side load" on the firing stroke?Which one would be better for max power?
Postby dpuckett » Thu Oct 08, 2009 5:52 pm
This is my personal opinion, and in no way based on scientific study or research. But, I'd think with the wider bowl (all else being equal) of the nonIC engines, that it'd have a slight advantage for shock dissipitation, and possibly a little more power production. The wider bowl will also lend itself to better super-uber-advance timing, for the reason you stated.
Dan
Postby crewcabxlt » Thu Oct 08, 2009 5:59 pm
ive noticed pods dont smoke as much with non i/c pistons. spray angle hits bowl a little better i guess.
78 ford crewcab,90 6bt,120k,pods,hx-35-12,ported parts.pump mods,3rd gen intercooler.dyno @298rwhp,808 tq uncorrected @4800 ft,dyno june 09 w/he-351turbo,364 rwhp-tq?,3 other 1st gens on the farm.
crewcabxlt
Postby Richie O » Thu Oct 08, 2009 6:00 pm
Ok, but,,, I thought the 9mm spray pattern was different then the 7 mm intercooled sticks???
Postby CaptainChrysler » Thu Oct 08, 2009 7:31 pm
I believe the non-IC spray angle is a little wider.
1993 W-350 EXT CAB SRW
GETRAG, DC-1'S, 285'S
370'S, HX40, 5" EXHAUST, BHAF
1989 W-350 SRW
GETRAG/NV273
P-PUMPED, 2.6" S400
WATER-2-AIR IC, SBC DD
CaptainChrysler
Postby crewcabxlt » Thu Oct 08, 2009 7:57 pm
the i/c piston is designed for improved emissions.
crewcabxlt
Postby peobryant » Thu Oct 08, 2009 8:35 pm
CaptainChrysler wrote:I believe the non-IC spray angle is a little wider.
I've read multiple times that the Non I/C spray angle is 155* and the I/C (even 2nd Gens) are 145*.
Postby CaptainChrysler » Fri Oct 09, 2009 4:16 am
Thats sounds right.
What angle are the marine 370's?
1989 W-350 SRW
GETRAG/NV273
P-PUMPED, 2.6" S400
CaptainChrysler
Postby peobryant » Fri Oct 09, 2009 11:18 am
CaptainChrysler wrote:Thats sounds right.
Marine injectors are 155*.
Users browsing this forum: No registered users and 70 guests
