Mark Nixon wrote:Are you running an early ('89-'91 nonI/C) vacuum pump assembly?
Reason I ask is the '90 Cummins I have with a broken cam lost it's bearings and the race was just hanging loose riding the shaft and it should have made a sound similar to that.
It does it just spinning the shaft as-is.
Not trying to "gloom and doom" you, but once bitten twice shy.
The early pumps are NOT pressure lubed like the later ones, not a great design, IMO.
