injector cleaning?
injector cleaning?
Postby wminmi » Fri Oct 09, 2009 5:24 am
Anybody know of a "how-to" write up on this?
Have around 300k on my '89, and I highly doubt the injectors have ever been cleaned....
Did a search and all I could find was the injector chart and other injector swap posts, nothing about cleaning and re-install.
TIA
Wm. Vining
South Haven, MI.
** '79 D-250 CC **
wminmi
smoke screw?
Postby dpuckett » Fri Oct 09, 2009 1:30 pm
Usually, you take them to an injection shop to have them cleaned and pop pressures reset.
Remove is pretty simple- remove the lines and retaining nuts, and pull them out. Ok, the last part is the hard part, but isnt so bad, either.
Dan
Postby mprmn08 » Fri Oct 09, 2009 7:24 pm
just take em out and soak them in diesel over night or something. good enough :D
mprmn08
Postby dpuckett » Mon Oct 12, 2009 4:30 pm
Um, dont they soak in diesel fuel all the time?
Postby mprmn08 » Mon Oct 12, 2009 4:53 pm
dpuckett wrote:Um, dont they soak in diesel fuel all the time?
i know it seems stupid but i did it to mine and it broke up alot of carbon. i had a pile of it on the bottom of the bucket i had them soaking in.
mprmn08
Postby PToombs » Mon Oct 12, 2009 5:48 pm
Only the insides! :roll:
Postby gear jammer 91" » Mon Oct 12, 2009 8:26 pm
I took mine apart and soaked the tips and bodies in a tub of carburetor cleaner. If you do it, just do them one at a time, and make sure they are absolutely clean before you put them back together, or your gonna have a leak.
01 LB7
gear jammer 91"
Postby Smokem1 » Tue Oct 13, 2009 7:25 am
Cleaning the tips off will do very little as far as R&R is concerned. You need to have them checked for opening pressure variance and seating area wear.
Smokem1
Postby gear jammer 91" » Wed Oct 14, 2009 5:07 pm
Smokem1 wrote:Cleaning the tips off will do very little as far as R&R is concerned. You need to have them checked for opening pressure variance and seating area wear.
That's probably why I couldn't tell a difference before or after. My truck wasn't running rough, I just had the injectors out while the head was being re-surfaced and I was bored.
01 LB7
gear jammer 91"
