Rear Axle?
Rear Axle?
Postby Bad93Cummins » Mon Oct 19, 2009 4:31 am
Is it a D70HD or D70?
Bad93Cummins
Postby ahale2772 » Mon Oct 19, 2009 6:04 am
im pretty sure the hd dosent have the taper at the end of the axle tube leading into the backing plate... i think..?
Postby rattlebox93 » Tue Oct 20, 2009 3:05 pm
70u is what these trucks have if it is a 70 and not a 60
rattlebox93
