ahale2772 wrote:not to change the subject but i saw a crank from a big Cat 1692 block that melted a piston and ruined the crank because the piston and rod wobbled so much in the bore it wore the crank journal wore an 8th of an inch.... that motor went to runaway i heard it was not pretty
ahale2772 wrote:in what aspects are a non ic head inferior to an ic head?
