abs delete parts napa
Postby dieseljack » Sun Oct 25, 2009 8:27 am
found these on another site now you dont have to search WEA 7917 & WEA 7828
1991 w250 rebuilt auto 170xxx Straight 4" turbo back dennyt stage2 fuel pin pump turned up 1/4 from bad new era 370s
dieseljack
Postby 921stgen » Sun Oct 25, 2009 10:04 am
Wjones posted on cumminsfourm, fitting WH202x5 and WH252x3 from napa.
91 W250 pods, , pull cable, Isspro FP gauge, Isspro boost, pyro, 366 spring, 91 W350, sold-92 W250, 40 hp Injectors, Bully Dog Fuel Pin, Isspro-tach, boots, pyro, AM electric fp gauge, 3200 GS, 5" AEM intake, 4" exhaust 5" stack
921stgen
Postby dieseljack » Sun Oct 25, 2009 12:20 pm
ANd not just any part numbers. These 2 numbers will ensure dependable consistent stopping for your 1st gen CTD Ram for many years to come. I got the fittings to bypass the useless RWAL valve on these rigs today. I will install them tomorrow as it is raining now, but here are the NAPA numbers-
WEA 7917 & WEA 7828.
Total came to $8.56 with tax. Well worth it, IMO. And I didnt have to buy any lines or do any flaring. Simply unhook and install the fittings in place of the RWAL module/ solenoid. I will try to remember to take pics tomorrow as I do it.
Daniel " i copied it from turbodiesel: jack
dieseljack
Postby dpuckett » Sun Oct 25, 2009 3:00 pm
I can tell you with near absolute certainty that the prices have gone up in the last 3-4 years. I priced some for my W350 last summer (08), and it was close to $20 for the two fittings.
In hindsight, I think one would be better off removing the lines from the ABS unit and reflaring the end of the brake line (from the MC) to go into the brake hose directly. Might be able to find an adaptor. and skip the reflare. The p-n's I had were to directly join the two lines going into the the ABS unit.
DP
Postby dieseljack » Sun Oct 25, 2009 3:07 pm
someone had the link to it saw it was older but thought it would help if thats the way you would want to do it
dieseljack
Postby dieseljack » Sun Oct 25, 2009 3:09 pm
im going to napa in the am will post new price
dieseljack
Postby RumbleFish » Sun Oct 25, 2009 7:30 pm
dear god, $20 for two fittings??? go NAPA :roll:
ill see what i can do about getting the part #'s for the fittings you can get at oreillys. stay tuned.
Re: abs delete parts napa
Postby jeff77indy » Wed May 26, 2010 7:44 am
MSC has these.
P/N
066861548 WH202X5 $1.16
62252432 Parker 461FHD-3-2 $1.70
Jeff
jeff77indy
Postby rebel horseman » Mon Jan 31, 2011 10:01 am
Just spoke with my local NAPA. The WEA numbers are correct.
WEA7917 is $4.99
WEA7828 is $6.80 (and is in stock surprisingly)
'93 Ram D350 Club Cab, ETC, G360, 366 spring, fuel screw screwed, star wheel bottomed, smoke screw flush, BHAF, straight pipe, DennyT Stage II pin. 182k miles.
rebel horseman
Postby idaho1990 » Wed Aug 10, 2011 7:32 pm
Does napa still have these? I cannot find them on their website....
1990 W250 drag truck. Benched 215 pump, s364 over s595, Contagious Diesel 5x0.020's with some work, Contagious Diesel Comp DV's, Dual fed, tork tek, Fire Ringed, hamilton springs, ARP 2000s, airdog 150, 3 piece manifold, Nitrous by NX, 47rh, np271, 3.07's, caltracs, rolling on Nitto 420 305/50r20s looking to break into the low 10s this spring
idaho1990
Postby idaho1990 » Fri Aug 12, 2011 12:34 pm
BUMP....anyone know?
idaho1990
Postby PToombs » Fri Aug 12, 2011 6:37 pm
They should have them in the Weatherhead box. It may not show on the website, I know a lot of stuff doesn't. The napaonline site has gone to crap in the last year or 2.
Maybe call and ask, it should show up in their computer.
Postby Hansen01 » Sat Aug 13, 2011 11:52 am
so, i went and bought the two fittings today, and i know where the abs deal is, but how do you manage to do this without buying line or flanging stuff? considering the two fittings i got have holes in them :?
Under construction...
Hansen01
Postby PToombs » Sat Aug 13, 2011 5:53 pm
You should be able to remove the 2 lines from the valve, remove the valve, screw the 2 fittings together and put the lines in the new fittings. It doesn't sound too hard to me, but I did mine a different way, so what do I know? ;)
Postby Hansen01 » Sat Aug 13, 2011 11:54 pm
lol most likely alot more than me, i thought about trying that but then realized if i broke somethin i would be without breaks till monday when the parts store opens :? il take a look at er tomorrow again, thanks :thumright:
Hansen01
Return to Part numbers (old,new,cross reference)
