front bumper
front bumper
Postby brokenbolt » Sat Oct 24, 2009 9:33 am
Hey everyone,
I pulled the heavy duty front bumper off my 93 and picked up what I was told a front bumper off another 93. The brackets that came with it where home made. So I went down to the wrecking yard and got another set of front bumper brackets off a 1989. I was told that the brackets would fit all truck front bumpers from 1988-1993. Anyways when I bolted up the brackets (guess what?) They did not match the front bumper holes. So what I need to know is what years will interchange with my 93. Oh yah, another guy told me that 91-93 would interchange.
93 ext. cab 4x4 stock for now! Remember you work to live, not live to work!!!!
brokenbolt
Postby RumbleFish » Sat Oct 24, 2009 12:44 pm
it should go all the way back to 85 or 86. my 91 had a bumper off my 87 ramcharger on it. sounds as if you might not have brackets that match your bumper, or vice versa.
Postby burnt_servo » Sat Oct 24, 2009 6:09 pm
poked around www.car-part.com and it looks like everything should interchange from 1981 to 1993 ......
i would not be surpised if the same part will interchange into the early '70's .
'93 w250 .... stock ...
burnt_servo
Postby RumbleFish » Sat Oct 24, 2009 6:47 pm
not quite. the 70's trucks use a different, smaller bumper and brackets. you can make it work, but you need a matched bumper/bracket set.
Postby Mark Nixon » Sat Oct 24, 2009 7:17 pm
'91-'93 (LE) use a frame extension bracket, anything else does not.
I will have pics up momentarily to illustrate.
Postby Mark Nixon » Sat Oct 24, 2009 7:37 pm
From what I have seen, these are on LE bumpers, but I honestly haven't paid attention to the few non-LE trucks I have seen to say if they have them or not, but it SEEMS like the non-LE trucks use the '90 style bumper.
Front bumper attached, wheel side:
Frame w/o bumper w/frame extension, wheel side:
Back side of frame w/frame extension:
With all of this, I did notice that my '90 C&C truck also has some other brackets that are designed to re-inforce the frame where the bumper mounts, which most other '90s I have seen DON'T have.
Postby Richie O » Sun Oct 25, 2009 6:21 am
Here is a pic of my 89 LE's bumper mount. The cut in it is where I had to relieve it for my powerstroke cooler to fit.
Postby Mark Nixon » Sun Oct 25, 2009 7:48 am
To the original poster, I do have a spare set of the '91-'93 bumper brackets if you end up needing some.
Also have a decent complete LE bumper, too.
Postby brokenbolt » Sun Oct 25, 2009 2:16 pm
My truck is an 93 LE. Do these trucks have the extension brackets on them because of the plastic piece that on the top of the bumper? What I was hoping to do is put a nice chrome front bumper that did not have the plastic on the top or the bumper guards. So if I got the bumper and brackets off a 89 they should still bolt up, right? Would the mounting holes on the bumpers be in the same location?
brokenbolt
Postby dpuckett » Sun Oct 25, 2009 2:55 pm
I think the extensions have more to do with the grille design than the bumper itself.
The plain bumper should bolt onto the 93 brackets.
Postby brokenbolt » Sun Oct 25, 2009 6:14 pm
I think that I was given the wrong front bumper. Does anyone have the ability to measure the carrier bolt holes (the distance in between the holes) on a late 80's truck and then on a 1993 front bumper?
brokenbolt
Postby RumbleFish » Sun Oct 25, 2009 7:33 pm
dpuckett wrote:I think the extensions have more to do with the grille design than the bumper itself.
this would make sense. again, i took the bumper off my 87 ramcharger and bolted it straight onto the brackets on my 91. it was the same bumper, minus the plastic stuff on top.
Postby brokenbolt » Mon Oct 26, 2009 5:30 pm
Was your 91 a LE?
brokenbolt
Postby RumbleFish » Mon Oct 26, 2009 6:48 pm
yes it was. it can be seen here, its the black/silver rig with the grille gaurd.
http://1stgen.org/viewtopic.php?t=5809
this bumper was off my 87 rc, it bolted right up to the 91 brackets. the 91-93 le bumper is the same as the non-le other than the plastic trim.
Postby brokenbolt » Mon Oct 26, 2009 9:10 pm
Just want to say thanks for all the help! You all have been great.
brokenbolt
