bypass abs
Postby Rebel Ram » Mon Apr 30, 2007 5:30 pm
hummin cummins wrote:the pedal almost goes to the floor until it works and when it is almost to the floor the brakes barely work... if i pump them they will get firm and work awesome but when i let off completely it gets soft again
Try this. Push the E-Brake pedal down to a goodntight spot. Then push on the brake pedal. If its firm now, you need to adjust your auto adjusters. Your getting too much shoe travel. Just another guess. But thats a common reason for mushy or pedal to floor action. Getting rid of the abs valve was still a good thing.
"Big Ugly"-93 3/4 T extra cab 4X4 5 speed
"Big Hips"-92 1 Ton reg cab 4X2 Auto
"The ohwun"-2001 3/4 T quad cab 4X4 auto
Rebel Ram
Re: anti lock
Postby BEARKILLER » Fri May 11, 2007 8:52 pm
charger 69 wrote:I wonder if the flexible brake lines are a problem.
Old worn-out stretchy brake hoses are very susceptible to poor pedal response.
The hoses deteriorate from inside out.
Also, some hoses will tend to suck together, making one think that the front calipers are hanging up; when, in fact, the hoses are sucking together, not permitting the fluid-pressure to be relieved.
When replacing, go ahead and get braided stainless; they won't expand.
MY TRUCK = 1985 FORD F-350 2wd, 89 1st.Gen.Cummins,Getrag 5-sp,Dana70 3:55
WIFE'S TRUCK = 1991.5 D-250 I/C, Auto
SON'S TRUCK = 1990 W-250 Getrag
#4 = 1991 D-350 LE Getrag
BEARKILLER
