Mark Nixon wrote:If it was running before and more or less just died, why would you need to bleed air out?
The way I read it, there was no warning, just BAM! dead.
Usually air will give a symptom.
I'm going with the dead solenoid theory.
I've seen them fail where they allow just a trickle of fuel through, but not enough to increase pressure to pop the injectors.
Besides, the pump will still push a little fuel even when the solenoid is disabled, but lacks pressure because the fuel supply is sealed off, much like the engine will crank faster if you block off air to the intake, put the supply of air back and it cranks slower.
RSWORDS wrote:....I was thinking ith the low level in teh tank....Plus when he took off teh gas cap he said there was alot of vacum on the tank, Maybe the vent is clogged and the lift pump wont pick up any fuel. Just thinking out loud.
