by Richie O » Mon Nov 09, 2009 6:07 pm
1STGENFARMBOY wrote:Richie do you think my truck would be quicker with the fuel turned down and put a 60mm compressor on the H1C, i already did the 16cm exaust upgraid?
Quicker, I don't think so. Basically all the 60 mm upgrade does is give you a little more air at a cooler temp. I have read that some people put a egt gauge in there turbo outlet ( to measure temp of compressed air ) and have had numbers 450 plus degrees ( on stock turbos at way over recomended presure). So as far as I know, if you kept your fuel settings the same you might gain a little power but the key is how long you can use the power. The upgrade should let you stay on it a little longer due to the turbo being more efficient at producing air at a lower temp and a increased cfm. The 60mm upgrade is a band aid upgrade. Most likely it will not cure your egt problem, just give a couple more seconds of power. My egt is well over 1500. It will pin the gauge in 4th gear with 4.10's.
