steering problems
steering problems
Postby Farmboy » Mon Nov 16, 2009 3:13 pm
Ok, so I got my new leaf springs put under the front of my truck... Have one problem though. The steering is messed up. I can get it to turn almost all the way to the right but I can't get it to turn left at all. actually it won't even go all the way straight. is there some way that I messed up the indexing of the pitman arm or something. It steered fine before I took it to the frame shop, and I didn't check it when I got it home... I just backed it straight in the garage off the trailer. So I am thinking I screwed something up when I was putting the leaf springs on. Any suggestions?
Farmboy
Postby Ace » Mon Nov 16, 2009 4:04 pm
Has the pitman arm been removed?
Postby burnt_servo » Mon Nov 16, 2009 5:24 pm
isn't the pitman arm " keyed " with a really wide spline to the shaft ?
what about the bracket , or frame holding the steering box being broken ?
'93 w250 .... stock ...
burnt_servo
Postby IowaCummins » Mon Nov 16, 2009 5:55 pm
burnt_servo wrote:isn't the pitman arm " keyed " with a really wide spline to the shaft ?
if i remember right its splines all teh way around but four splines are different so that you can posision it in four different ways so i would try putting the wheels straight then find the middle of your turing revoulutions adn then puit it back on. thats what i would do
IowaCummins
Postby Ace » Tue Nov 17, 2009 6:54 am
IowaCummins wrote:if i remember right its splines all teh way around but four splines are different so that you can posision it in four different ways...
Yep, that's the deal, so I suppose if you somehow managed to put it back together 90 degrees off you might see the behavior Farmboy is describing.
I'd be going back there with a baseball bat if the frame shop that was working on it actually accomplished that trick without even checking it before returning the truck.
Postby Farmboy » Wed Nov 18, 2009 3:55 pm
I don't belive that they took it apart, but they might have. I will look and see if it looks like they took it off. I wanted to take it apart to see what kind of movement I get with out the wheels hooked to it.... now just for some more time to work on it :x
Farmboy
Postby PToombs » Wed Nov 18, 2009 6:33 pm
I wonder if somebody clocked it before. I did a little figuring on it, and it sounds like when it was lifted, it pulled the wheels to the right. To compensate the wheel had to be turned left to be straight, which is where you are at. And the gearbox is all the way left now.
How much did the front come up? It had to come up a long ways for that to happen.
Postby Farmboy » Thu Nov 19, 2009 5:40 am
The new "stock" springs only lifted it up about an inch or so. So i don't think that would be the issue.
Farmboy
Postby PToombs » Thu Nov 19, 2009 6:24 pm
Right, shouldn't bother that much!
Postby Ace » Fri Nov 20, 2009 8:37 am
Without addressing the geometry (drop pitman), an inch of lift equals about 30 degrees of steering wheel arc, by my estimation....
Postby Farmboy » Wed Nov 25, 2009 6:05 am
Well I am going to tear into the steering box tonight and see what I find. Any advice on what to watch out for as I go in?
Farmboy
Postby Ace » Thu Nov 26, 2009 10:13 am
You will probably know right away whether or not they had the draglink/pitman off. It will either come apart easily, or it won't.
Postby Farmboy » Tue Dec 01, 2009 5:24 pm
Well, I started by taking the top of the steering box off and found out that the pinion gear (which has three teeth) was broke. The center tooth broke off in the accident and either the trip to the frame shop or the jolting on the frame machine made the piece of gear drop down and bind everything up. Took a magnet and pulled the chunk out of there and everything turned nice and free. So I am going to go to the local Pull-A-Part and get another steering box. They only want like 30 bucks for one. By the way they definatly did not have my pitman arm apart from the drag link. EVERYTHING was rusted fast!!!! :x
Farmboy
Postby Ace » Tue Dec 01, 2009 6:21 pm
Well, that sure explains that, then! :shock:
Postby PToombs » Tue Dec 01, 2009 6:31 pm
Yup, that'll do it! :lol:
