Body Mounts
both inside and out
Body Mounts
Postby ktekst » Thu Oct 01, 2009 1:26 pm
Does anybody know any aftermarket places I can go to get body mounts? I am basically doing a frame off resto. on my truck and my body mounts are pretty tortured, I have a dodge parts man looking up what they can get but I thought id ask if anyone knows after market ideas. My truck is a 92 w250 extended cab if it matters.
I thought about energy suspension but they only list ones that fit up to 1985 and my dad talked to them on the phone and they said they had a note that said they wouldnt work on the newer trucks.
Thanks in advance guys, ktekst :grin:
ktekst
Postby PToombs » Thu Oct 01, 2009 5:58 pm
I hacked 2 off the 86 donor frame that were the same as the front cab mounts on my 92. The rear ones are different, so I just cut the flat piece out and made a plate with a hole and welded that back in.
Postby ktekst » Fri Oct 02, 2009 2:34 pm
Thanks PToombs but I am sorry I wasnt clear in my post to start with, I am talking about the body mount bushings or whatever they call them. I am guessing they call them an isolator or bushing. My fault for not being clear.
ktekst
Postby 95ram » Sat Oct 03, 2009 2:16 am
I believe this is what you're looking for.
http://www.amazon.com/Energy-Suspension ... 329&sr=8-1
95ram
Postby ktekst » Sun Oct 04, 2009 5:38 am
95ram, Have you used these on a 86 and newer truck before?
When we talked with energy suspension they talked like these wouldnt work with 86-93 trucks.
Thanks ktekst
ktekst
Postby 95ram » Mon Oct 05, 2009 5:28 am
ktekst wrote:95ram, Have you used these on a 86 and newer truck before?
Thanks ktekst
I have not, but others over on DTR have and they worked. I dont unerstand why they wouldn't work. My 84 looks to be the same as my 91 and 93.
95ram
Postby oilcan64 » Tue Nov 17, 2009 6:43 pm
i just checked the link, they dont sell them for a 92 w250
1992 - w250 - 5 speed - LE - Reg. cab - 8' bed - minor pump tweaks - srw - ic
KDP & Killer Bolts killed
Saving for body work!
oilcan64
Return to Body
