New idea for piston pump upgrade!
I did
Postby ZSkibo » Sat Nov 21, 2009 4:16 pm
I'm running the 1/2" drawstraw. 1/2" lines all the way to the IP and a 1/2" return line. I never see under 15psi and usually have 18psi at idle. We'll see what happens when I go to 5x18's.
92 W250 Pump bombed, AFC out, 366 spring, 18* timing, KSB hotwired, HX35 12cm non wg, New Era 6x18's, BHAF, 60 lb in/ex springs, 4" PAC Brake, onboard air, Nathan P3 horns
ZSkibo
