fuel system volume?
fuel system volume?
Postby Redneckintraining » Mon Nov 23, 2009 9:21 pm
Just wondering what is the approximate volume of the supply lines,the return lines and the IP itself?Looking to run a two tank system with some sort of fuel that is black.I am thinking of going with a 6 port selector valve.Problem is that both return and supply lines get switched so whatever volume that was in the lines/ip ends up contaminating the diesel tank.Im just wondering about how much that would be.
thanks.
Redneckintraining
Postby Mark Nixon » Tue Nov 24, 2009 9:40 am
If you know the length and inside diameter of a run of pipe or tubing, there's a formula to figure it. I believe it's the "cylinder volume" formula.
A 1st gen fuel filter holds just slightly above a pint (18 ounces, +/- an ounce or 2) IIRC.
I'm assuming putting a bit of clear product into the black tank won't hurt anything?
Postby dpuckett » Tue Nov 24, 2009 8:44 pm
cylinder volume= pi x R(squared) x height (or length of hose, in this case.)
Postby Redneckintraining » Wed Nov 25, 2009 11:33 am
Im just looking for an aproximate time that it would take to purges the line of black liquid and only have clear liquid in them.Usefull for shutdown...
Redneckintraining
Postby IowaCummins » Thu Nov 26, 2009 2:29 am
you couldnt install check valves in each of the fuel supply lines to the 6 port reg?
IowaCummins
Postby Redneckintraining » Thu Nov 26, 2009 5:06 pm
a 6 port switch switches all lines at once.so whatever was in the IP/lines before you switched over goes into the tank you just switched to.
Redneckintraining
