Plastic washer?
Plastic washer?
Postby Viking » Thu Nov 26, 2009 11:54 am
Hello, and greetings from finland!
Yesterday i had an idea and started to rotate the fuel pin of my ´93 cummins ( i want little bit more power and black smoke of course). What is the meaning of the white plastic washer at the top of the fuel pin? Limit the movement of the pin? Is it necessary?
1993 POWER RAM 4x4 LE, long bed,reg cab
Viking
Postby cedardiesel » Thu Nov 26, 2009 12:01 pm
Well some trucks you can remove it and allow pin to move further down and when you remove it from some it it allows pin to travel to far and it will go to deepest part then start widdening back out. So you may be able to remove it or have to just shave it down some so you make it go down to the deepest part
90 W250 4x4 5spd pump Ve cranked wide open, BHAF, HX35 with all 2.5" intake piping, and 4" straight piped
92 W250 4x4 5spd P-pumped B1B over B2 are on and now slippy clutch
cedardiesel
Postby Viking » Thu Nov 26, 2009 1:44 pm
But it will not brake anything even if it is removed??
Viking
Postby TWorline » Thu Nov 26, 2009 2:46 pm
Welcome from Finland! No it will not break anything if you take it out. As was mentioned it will allow the fuel cone to go deeper in the bore resulting in more fuel being thrown on the fire.
Tim Worline
http://www.CoolerTubz.com/
TWorline
Postby soggy » Thu Nov 26, 2009 3:53 pm
Welcome, where are you located in finland?
92 W250 VE Powered
13.31@ 98.92
1993 D350 Tow Rig
soggy
Postby Richie O » Thu Nov 26, 2009 4:28 pm
I wonder if it could alllow the fuel cone to go down to far and put a side load on the little fuel pin. I know on my 93 when I looked at the wear mark on the cone I could have just shaved some of the washer off. If I had removed it, it would have allowed the cone to go to deep.
Postby PToombs » Thu Nov 26, 2009 4:37 pm
I agree with Rich. Mine was the same way. I just shaved the washer down with some sandpaper.
Look at the mark on the cone, and kinda measure the distance to the top where it widens out, then compare with the thickness of the washer. If the washer is thicker, then shave it thinner, if the distance is greater, remove the washer.
Welcome to the site!
Postby Ace » Thu Nov 26, 2009 4:46 pm
Mine ended up using a little less than half a washer. Actually replaced it with one of the correct or best thickness.
Postby Viking » Fri Nov 27, 2009 12:49 pm
soggy wrote:Welcome, where are you located in finland?
Small town called HAAPAJÄRVI.
http://fi.wikipedia.org/wiki/Tiedosto:H ... i.2008.svg
Here is a link to see the location on map. I hope it works.
Viking
Postby Ace » Fri Nov 27, 2009 1:43 pm
Viking, how far is that from the F18 plant in Jämsä? Looks to be just north...
Postby Viking » Sat Nov 28, 2009 12:34 am
Ace wrote:Viking, how far is that from the F18 plant in Jämsä? Looks to be just north...
About 155 miles from here..
Viking
Postby Ace » Sat Nov 28, 2009 7:41 am
I spent a few weeks in Jämsä at the F18 plant there about ten years ago. I didn't see any Dodge pickups around, but sure did see alot of nice scenery, places and people. Beautiful country.
Postby Viking » Sun Nov 29, 2009 3:04 am
Ace wrote:I spent a few weeks in Jämsä at the F18 plant there about ten years ago. I didn't see any Dodge pickups around, but sure did see alot of nice scenery, places and people. Beautiful country.
Ten years a go dodge trucks were very rare in Finland, last few years people have bought dodges from Usa, Germany, Sweden and also in Estonia because the prices and taxes is much lower in those countries than this automobile hell called Finland. And nowadays you can see dodges more often than gmc or chevy pick-ups..i think.
Viking
Postby Richie O » Sun Nov 29, 2009 9:36 am
Well, you have found a good site to read up on stuff. This site has some of the best 1st gen minds around. ME NOT INCLUDED. :lol: Im just the house cleaner. :roll:
Postby dpuckett » Sun Nov 29, 2009 7:50 pm
I had a classmate in horseshoeing school from Joensuu. Not sure where that is in relation to you.
Welcome to the best 1stGen site on the planet.
Dan
