??? with performance terms
Postby mrsemi05 » Fri Dec 04, 2009 6:46 pm
okay im new to the cummins but been wrenchin on DSL for awhile now. and im gettin ready to do a cummins swap into a 1994 chevy 3/4 ton and i have a few ???? about performance before i am ready to install the engine.
1 what the hell is a 4 gsk
2 DVs 191 or 022s what is that????
3 5x.016 or.018 what is that???
i got this info from another site and unsure what it means and the guy that gave it to me no longer responds so any help would be great and what i got is below
p-pumped 12valve w/180 or 215 pump - $1500
S300 in 64 or 66mm for daily driving. - $1500 less used.
downpipe- $200
5 x .016's or .018's - $600
4 gsk- $150
#60 valve springs- $150
titanium retainers harnded keepers- $350
DV's 191 or 022's- $225
mrsemi05
Postby Richie O » Fri Dec 04, 2009 6:57 pm
Sounds like P Pump stuff. That is second gen stuff. We mostly deal with 89 to 93 VE powered trucks.
Postby mrsemi05 » Fri Dec 04, 2009 7:01 pm
oh the P pump is 2 Gen??? i was told it was 1st Gen as you can see i dont know much about these cummins :)
mrsemi05
Postby PToombs » Fri Dec 04, 2009 7:27 pm
Yup, p-pump is 94 to 98. I'll help you with the other terms too. Just don't tell the other guys I was this nice, I don't wanna ruin my rep. ;)
A 3 or 4 gsk is a 3 or 4000 rpm governor spring kit.
DV's are the delivery valves in the injection pump (IP) The numbers are the sizes.
5x .016 or.018 are injector sizes. 5 holes, .016 or .018 diameter holes.
You shouldn't need the titanium keepers unless you are revving it way up and keeping it there for very long. And you probably don't need the DV's either. Unless you are building a real racer, and looking for 5-600 horsepower or more.
Postby mrsemi05 » Fri Dec 04, 2009 9:33 pm
well i thank you for clearing me up on the terms and i am planning on makeing 600 HP is that plasiable for the first gens motor????
mrsemi05
Postby meby » Sat Dec 05, 2009 11:48 am
mrsemi05 wrote:well i thank you for clearing me up on the terms and i am planning on makeing 600 HP is that plasiable for the first gens motor????
Only one or two people have managed to sqeeze 600hp out of a VE powered 1st gen. Good luck. :D
-1991 D-250 bone stock
-1997 Civic Hatchback
-Case 530 CK
-Speedex Walking Tractor.
-BCS Walking Tractor
www.ebyfarmsllc.com
meby
Postby mrsemi05 » Sat Dec 05, 2009 1:02 pm
well thats what ill be shooting for and i hope you guys will help me get there
mrsemi05
Postby peobryant » Sun Dec 06, 2009 3:03 am
mrsemi05 wrote:well thats what ill be shooting for and i hope you guys will help me get there
If the truck is a daily driver, you'll want to limit yourself to around 400-450rwhp. After that, you'll need a 14mm h/R for the VE, which has proven to be very unreliable with daily driving, because it needs a lot of fuel to cool it. If you P-Pump it though, 600rwhp shouldn't be a problem.
Postby mrsemi05 » Sun Dec 06, 2009 10:37 am
yeah i have been told that alot. so how hard is it to p pump one of these???
mrsemi05
Postby peobryant » Sun Dec 06, 2009 11:10 am
mrsemi05 wrote:yeah i have been told that alot. so how hard is it to p pump one of these???
Generally it's easier and cheaper to just swap a 2nd Gen 12 Valve engine in, rather than finding all the parts needed for a swap. Plus you'll have 2 running engines so you could sell the VE stuff pretty easy.
Postby Diesel Dawg » Tue Dec 08, 2009 5:34 am
the engine he listed as looking at is a p-pump engine.
Diesel Dawg
