This post is of course about the VE pump fuel adjustment screw. I will start with a little information about the application and the pump. The Pump is actually on an IH D358 Motor, it has a 12mm head just like the dodge truck application but it does not have the fuel control device on top with the AFC to limit fueling in low boost conditions. It looks like the pump was set to 150hp at the flywheel from the factory in it's application , which is probably somewhere around 80-100cc's of fuel. This engine was taken from a cotton picker and placed into a tractor that I pull with. I removed the collar that was preventing the fuel screw from being moved inward and ran a tap over the threads to clean them up, when I put the fuel screw back in, it would only go about 1/4 of a turn more than what it already was. I have read that there were also dodge trucks that had the same problem of not being able to adjust the fuel screw in farther, what have you done to give yourself more adjustment? I haven't taken the pump apart yet, but that is my next step, I need to get as much fuel from this pump as possible and will eventually get a 14mm head for it, but there should still be a lot of potential in this 12mm head. I am hoping to see over 300 hp with this pump, which according to the results on this board, should not be any trouble at all. I am currently running a hybrid H1c/H1e Turbo on the engine, but hope to go bigger as soon as I can get more fuel to drive the larger turbo. I am also looking for other mods that I can do to the pump internally or externally to get more performance out of it. I am going to pick up a 3200 rpm spring and put an electronic lift pump to supply it fuel (it is currently gravity fed, like in it's original app). I don't have a fuel pin to change or grind on, so what other mods am I looking at? I have read lots of info on this pump and will be tearing into it soon, but would like some more insight. My max RPMs will typically be 3,000.
Oh and I do have a Dodge/Cummins truck, but it pulls the trailer so I don't think I will do anything to it for now, it's got plenty of power.
