Hey Everyone.
This is my first post so here it goes. I purchased a 92 D250 with a getrag a few months back. It is all stock so far. I have gone through the truck and changed all the fluids/filters and filled up the transmission an extra quart. I've been driving as much as I can and the truck has been running great so far. Recently I rotated the fuel pin 90 degrees and turned the star wheel a turn and a half just to see how it would go. Nothing too crazy. It worked great and the result was better than expected. That was a week ago and now the truck has not been running the same. Before the truck would rev up nice and smooth as the boost rose and speed increased. Now it seams the engine does not rev as smooth and the the power is not their like before. I'm trying hard to explain this as best i can. The engine seams to be reving higher with less power. What could this be? A lack of boost? There is only a little smoke with hard acceleration so I dont think it is. I check the seals around the banjo bolt and the afc itself for leaks. I'm not sure where to start. Could it be the fuel pressure? The only thing that has been done since I turned the pin was a fill up and added some fuel treatment.
Any ideas would be greatly appreciated.
I dont know if you guys are like me, but when something is broken I cant stand not getting it fixed asap. Sorry for the long post
-Thanks again. Cant wait to learn as much as I can here.
