3rd gen air to air
3rd gen air to air
Postby jwatso8 » Fri Jan 01, 2010 8:11 pm
i can pick up a 3rd gen air to air for $225. it was taken out for an upgraded one. i was just wanting to know would it fit with out to much cutting?
SOLD 92 D250 intake,S300,coolertubz,i/p MAXED,366 spring,Dennyt fuel pin,DDP 4,airdog 100,gauges, 4" d/p w/5" stacks
TRADED IN07 2500 6speed,intake,CFM+,Edge EZ chip,MBRP exhaust,B&W hitch
NEW 2010 3500 6.7L DRW 4x4 CrewCab 4.10 grears
jwatso8
Postby IowaCummins » Fri Jan 01, 2010 9:52 pm
those are some tall tall units. i thnk you would have to cut out most everything under the radiator to fit it.
IowaCummins
Postby jwatso8 » Fri Jan 01, 2010 10:52 pm
well its a cheap price :lol: and my EGT's are in check (never go over 1200f) i just thought it would flow better than the stock. since stock is 2.5" in and outlets and the 3rd gen has 3" in and oulets and i got the 3" cooler tubes already on the truck. plus im after every bit of horsepower.
jwatso8
Postby IowaCummins » Sat Jan 02, 2010 12:24 am
im thinking if you get it to fit you will most likely be the first one to have a 3rd gen IC. cooling yes i think it would deffinately cool y adown quite a bit. i say get teh measurements off it and take your grille off and see how far it goes down there. you knwo i think one guy did do a 3rd gen IC. i remember seeing a truck that when y alook from the front you saw a good 8" of intercooler hanging below the grille
IowaCummins
Postby pulltilbroke » Sat Jan 02, 2010 1:15 am
It has been done but you got to cut the frame horns off
Postby jwatso8 » Sat Jan 02, 2010 1:24 am
so sould i just hold out for a 2nd gen CAC?
jwatso8
Postby burnt_servo » Sat Jan 02, 2010 6:11 am
jwatso8 wrote:so sould i just hold out for a 2nd gen CAC?
i would ... or get one out of a ford .
even the stock 1st gen one isn't that bad .
i've got a 3rd gen intercooler , and too me it looked like it would weaken the frame too much by the amount of material that would have to be removed to make it work .
'93 w250 .... stock ...
burnt_servo
Postby oldestof11 » Sat Jan 02, 2010 11:40 am
Over on DTR Greg (Gxxxx some type of numbers) had one in his old rig.
Postby RumbleFish » Sat Jan 02, 2010 4:57 pm
yep, and iirc he had to cut the first few inches or so off the frame to make it work.
Postby jwatso8 » Thu Feb 04, 2010 10:14 pm
Does the 2nd gen CAC have 3" end on them? I can pick up one for $200 off of craigslist.
jwatso8
Postby pulltilbroke » Fri Feb 05, 2010 12:57 am
IIRC there 3.5"
Postby Mark Nixon » Fri Feb 05, 2010 8:33 am
I'm considering a 2nd Gen one for the carhauler, mainly because it's easier to install than a P/S one and easier to find.
My only reservation is cutting up a super decent 1st gen I/Ced core support to make it fit. :cry:
The cooler will cost me under $100, which is another reason I'm considering 2nd gen stuff. :lol:
Any ideas on the efficiency difference between a stock 1st gen 'cooler and a 2nd gen?
Re: 3rd gen air to air
Postby RSWORDS » Fri Feb 05, 2010 10:41 am
jwatso8 wrote:i can pick up a 3rd gen air to air for $225. it was taken out for an upgraded one. i was just wanting to know would it fit with out to much cutting?
You can get a 7.3 powerstroke for half that and it will fit better and be an easier install.
RSWORDS
Postby Ace » Fri Feb 05, 2010 10:54 am
And the 7.3 coolers actually fit in there quite well if you do it just right:
http://stuff.is-a-geek.net/PhotoAlbum/1 ... TD_109.jpg
No grill trimming or anything un-cosmetic like that really required. 8)
Postby ahale2772 » Fri Feb 05, 2010 11:06 am
if its big and has no leaks go for it, proven methods arent going to be enough if u are going for high hp...
