normal?
normal?
Postby stock91w350 » Mon Jan 11, 2010 5:57 am
ive had my truck for about 6 months now, we have had some pretty cold days so far but i never noticed intill this morn that when i started it it ran kinda ruff for about 10-15 seconds. is that normal? its 5 degrees out. it started after turning over 2-3 times and it usually starts after turning over 1-2 times
stock91w350
Postby peobryant » Mon Jan 11, 2010 6:35 am
Mine kinda does that too. While mine doesn't run rough for 10 secongs, when I start her cold, she'll run rough for a few seconds, and shake the whole truck. I *think* it's normal, and it misses because of the cold. You could try and cycle your grids twice, and see if that helps.
Postby diesel freak01 » Mon Jan 11, 2010 7:58 am
mine does that kinda bad when shes cold also. i started cycling twice and it seemed to help but then i read some more (under the sun visor) and held the throttle open about half and it has more or less cured my problem runs rough for maybe a 2 seconds and then it smooths out just fine might try that.
1993 d350 ctd drw 2wd auto
diesel freak01
Postby oldestof11 » Mon Jan 11, 2010 4:46 pm
I live in a apartment with NO hook up for electric. It shakes rumbles and growls for about 5 mins after she is able to run with no throttle input.
Postby Richie O » Mon Jan 11, 2010 4:48 pm
Its normal.
