fuel tank
both inside and out
fuel tank
Postby jwatso8 » Fri Jan 08, 2010 2:18 am
stupid question, how many gallons does our trucks tank hold :roll: (to cheap to fill the tank to find out) thanks
SOLD 92 D250 intake,S300,coolertubz,i/p MAXED,366 spring,Dennyt fuel pin,DDP 4,airdog 100,gauges, 4" d/p w/5" stacks
TRADED IN07 2500 6speed,intake,CFM+,Edge EZ chip,MBRP exhaust,B&W hitch
NEW 2010 3500 6.7L DRW 4x4 CrewCab 4.10 grears
jwatso8
Postby Richie O » Fri Jan 08, 2010 2:15 pm
30
Postby peobryant » Sun Jan 10, 2010 1:16 am
All 1st Gen diesels had 30 gallon tanks. 2nd Gen's went to 35 gallon tanks I believe.
Postby Nate » Mon Jan 11, 2010 10:15 am
I can only get 22gal in my 92 w250.
Nate
Postby Ace » Mon Jan 11, 2010 10:22 am
Nate wrote:I can only get 22gal in my 92 w250.
That's due to the very highly accurate and reliable sending units found in these trucks. :roll:
Empty it, try it again, and I guarantee it will take 30 gallons. 8)
Don't try to drive to the filling station after you empty it! :P
Postby BobS » Mon Jan 11, 2010 12:51 pm
I think there are at least two date stamps on the tank. The number in the middle is the number of US gallons capacity.
BobS
91.5 W250 NV4500 Conversion
89 D350 Stock
BobS
Postby Nate » Mon Jan 11, 2010 7:06 pm
so your saying im filling up when i actually still have 8 gallons of fuel oil? hmmmmm, next time im on empty(or so it says) ill take a looksy. ive only owned the truck for less than a year, so for all i know the tank could have been replaced, i do know its some type of plastic. im curious now though. thanks Ace. ~Nate
Nate
Postby Richie O » Mon Jan 11, 2010 7:22 pm
It may have been replaced with a smaller gasser tank.
Postby peobryant » Tue Jan 12, 2010 5:55 am
I know when my low fuel light comes on and stays on, it takes 24 gallons to fill up. I've driven a few days with my low fuel light on, and when I filled her up, it took 28 gallons. I'd rather have my low fuel light come on with 6 gallons left, rather than 2, it's easier on the wallet. :lol:
Postby Ace » Tue Jan 12, 2010 6:21 am
Nate wrote:so your saying im filling up when i actually still have 8 gallons of fuel oil?
Yes, the fuel gauges tend to be very pessimistic, which like Peo says is probably a good thing if only from the standpoint of making it more difficult to actually run out of fuel. My low fuel light comes on with over ten gallons left. I know this because I drove it another 20 miles and still siphoned out 10 gallons before dropping the tank once a couple years ago.
Postby cell » Tue Jan 12, 2010 12:21 pm
The build sheet I got from chrysler says that I have a 24gal fuel tank. Never filled it up past 22 gallons either.
cell
Postby Richie O » Tue Jan 12, 2010 5:25 pm
cell wrote:The build sheet I got from chrysler says that I have a 24gal fuel tank. Never filled it up past 22 gallons either.
I have a 89 factory service manual and it says 30 gallon was the standard tank for a diesel truck. They do list a 24 gallon for the V8 and V6. I have my window sticker somewhere and I think I remember it saying 24 gallon tank on the standard equipment side then on the option side it listed the 30 gallon tank as part of the diesel option. Not saying you don't have a 24 , just passin along my 2 cents. :D
Postby cell » Tue Jan 12, 2010 8:43 pm
I see, now that would make sense. I'll have to take a look at the stamp on the tank now.
cell
Return to Body
