wheel studs
wheel studs
Postby jwatso8 » Wed Jan 13, 2010 9:47 pm
does anyone know part numbers for 9/16" wheel studs.
SOLD 92 D250 intake,S300,coolertubz,i/p MAXED,366 spring,Dennyt fuel pin,DDP 4,airdog 100,gauges, 4" d/p w/5" stacks
TRADED IN07 2500 6speed,intake,CFM+,Edge EZ chip,MBRP exhaust,B&W hitch
NEW 2010 3500 6.7L DRW 4x4 CrewCab 4.10 grears
jwatso8
Postby PRINCETON_JAKE » Thu Jan 14, 2010 9:06 am
2wd or 4wd? front or rear? If its 2wd there is no stud made that will work, because of the size of the knurl.
1992 cummins, 2wd, A518, WH1c, 60mm,12cm housing, fuel screws maxxed, fuel pin turned and ground, 3200rpm spring, big Amsoil air filter, 4" stack, timming bumped, piston lift pump, Bosch 190's, 18" Maxxi Hulk rims, and Nitto Terra Grapplers.
PRINCETON_JAKE
Postby jwatso8 » Thu Jan 14, 2010 2:29 pm
its a 2wd truck. they dont even make one if you drill out the stud holes bigger? is it just the size of the hole or the lenght of the knurl that why they dont fit? im willing to drill the hubs out bigger, i just dont want to make 50million trips to the parts store.
jwatso8
Postby PRINCETON_JAKE » Thu Jan 14, 2010 9:52 pm
I dont have the specks on me, but the factory 1/3" wheel stud has a knurl diameter of like .700", and the biggest 9/16 I could find was like .680". I work at a parts store, so i spent a long time looking for some for my own truck, i even went to the competetors and dug threw there catalogs. NOTHING. The only thing I could find was ARP said they would make them for me, but I decided not to.
PRINCETON_JAKE
Postby Ace » Fri Jan 15, 2010 8:57 am
I basically went through the same thing when I was trying to come up with a wheel/tire combo. At first I just wanted to upgrade the studs and get wider wheels with a little more offset. The studs seemed to be made of unobtainium. One guy somewhere said there was one with a "close" knurl that could be used if you had a heavy press to get them in, but I don't generally do stuff like that as a rule of thumb. I have a 20-ton press, but some things should never be kludged like that.
Postby GO OVRIT » Wed Jan 20, 2010 4:33 pm
Its easy for us 4wd guys. Just order studs for an 80's chevy k-30. If I remember right they were about 3/16th's longer too. I still haven't done the rear, so I can' thelp there.
GO OVRIT
Postby Ace » Wed Jan 20, 2010 4:35 pm
GO OVRIT wrote:Its easy for us 4wd guys. Just order studs for an 80's chevy k-30.
Where were you when I was looking for studs two years ago?!! :(
Postby adam greene » Mon Jan 25, 2010 5:57 pm
are the rear studs on a dually 9/16s to
adam greene
Postby dpuckett » Tue Jan 26, 2010 11:52 am
dually studs are 5/8"
