new fuel pin
new fuel pin
Postby IowaCummins » Sat Dec 19, 2009 11:03 am
alright its just in testing stages right now but i have been playing with a fuel pin design for quite a while and im just getting some made. i dont have any other fuel pins to compare to cause all i have had is the stock 70 pin and that is the only one i have seen in person. but the one i have in my truck righ tnow is out of mild steel cause i wanted to see how it would fuel. i dont expect this pin to last 100 miles cause of the soft steel, but the final ones will be made out of alot harder and better quality tool steel. the mods are in my sig, total boost in overdrive was right around 52 pounds, 3rd through 1st was around 45 pounds. egts were 1250 1-3rd gear, and max pull in O/D were around 1325. my new fuel pin 1-2nd gear 45 pounds, 3rd gear 50lbs and O/D was right around 55-56 pounds.
max egts were right aroudn 1400, never got above that. here are some pictures of the fuel pin next to the stock "70" pin.
IowaCummins
Postby ahale2772 » Sat Dec 19, 2009 4:00 pm
might consider making some kind of visible notch on the top of the pin so that when its in the truck with the diagphram on you can see where 90 degreese to the motor is.... just an idea
Postby KTA » Sat Dec 19, 2009 4:48 pm
Looks pretty deep at its deepest point. How bad does it leak fuel into the diapraghm area at full boost?
Postby IowaCummins » Sat Dec 19, 2009 6:18 pm
i have been keeping a close eye on that. and no fuel has been leaking so far. this is the first one. so i am seeing where the pin is traveling and i will adjust the next cut.
IowaCummins
Postby Richie O » Sat Dec 19, 2009 6:21 pm
KNOCK ON WOOD, so far my 93 has no leaks with a M2 which is as deep as that. Been a thousand miles of so.
Postby IowaCummins » Sun Dec 20, 2009 1:43 am
i have just around 140 mile on her so far and has been pulled every 40-50 to check for all of the above.
IowaCummins
Postby IowaCummins » Fri Jan 15, 2010 6:20 am
yesterday i just finished a new profile for the cut. got one pin polished and is getting heat treated today. hopefully no warping when heat treating! then if there is none its getting tested in the truck for a week whilel i make a new profile for less fuel. im goign to make this one less agressive and be like the TOW pin compared to the GO pin. haha alright off the metal shop
IowaCummins
Postby pitman » Fri Jan 15, 2010 7:12 am
That looks just like a denny t.
Single wheel 4x4 3/4ton 5_speed cummins. 100 horse injectors. Denny t fuel pin. Raptor fuel system. 1/4inch afc boost lines.!!!17 years old and a proud contributor to global warming!!!
pitman
Postby BC847 » Fri Jan 15, 2010 10:18 am
pitman wrote:That looks just like a denny t.
Not at all. ;)
@ IowaCummins
I like the very gradual ramp you have from minimum fueling to max. ;)
Postby crewcabxlt » Fri Jan 15, 2010 10:54 am
nice- i like to see r&d. i grind my own. keep in mind cutting much deeper than stock wont get any more fuel, (unless you count leaking in to afc.) the afc lever hits the insiide of housing. to get more fuel you have to grind a little off afc lever. 1/8 + then you still have afc control for faster spool-up. (i need that at my elevation, 4800 ft.)
78 ford crewcab,90 6bt,120k,pods,hx-35-12,ported parts.pump mods,3rd gen intercooler.dyno @298rwhp,808 tq uncorrected @4800 ft,dyno june 09 w/he-351turbo,364 rwhp-tq?,3 other 1st gens on the farm.
crewcabxlt
Postby unixcowboy » Fri Jan 15, 2010 12:24 pm
http://www.cumminsforum.com/forum/attac ... n-side.jpg
That's my Ol Smokey that I modified somewhat.
With my 6x.016's I hit 57 psi before I connected the wastegate...
http://www.cumminsforum.com/gallery/sho ... hoto/13395
This is the front view pic right now but I'm not getting a track towards the deepest cut, only ~ 2/3 way down.[/img]
'93 D250 CC 47RH w/goodies HX-40 60/65/17 w/hx50 flange 55 psi CoolerTubZ 6x16's M2 pin, 4"dp->5" pipe->5" Stack, PS IC
unixcowboy
Postby Mark Nixon » Fri Jan 15, 2010 1:17 pm
Sure would be nice to just BUY one that you don't have to pay through the nose for!
I mean, more than $50-$60 seems pretty spendy to me.
Postby lectro_static » Fri Jan 15, 2010 1:26 pm
I think there is a pretty good amount of money being put into making them, I know m&h pins are hardened and chromed. I would like to see them cheaper but I dont think $100 is completely out of line.
weeping head gasket
4" straight pipe
M&H M3 fuel pin
M&H Dynamic Timing Advance
366 spring
Auto Meter EGT and Boost
lectro_static
Postby BC847 » Fri Jan 15, 2010 2:51 pm
crewcabxlt wrote:nice- i like to see r&d. i grind my own. keep in mind cutting much deeper than stock wont get any more fuel, (unless you count leaking in to afc.) the afc lever hits the insiide of housing.
Oh yes it will. Without the lever hitting. :)
Postby IowaCummins » Fri Jan 15, 2010 3:09 pm
well got the new heat treated and tempered fuel pin done today. with the current cut i have it is not leaking fuel from the o ring. i have only ran this one today for about 10 miles and so far it has been exelent. it is deffinately a fuel mod. lol with the stock one in egts max maybe 1300 this baby in i think you could hit 1600 if i held into it longer. but righ tnow i will run it to 1450 and let off and continue throttle at 1300 and pulls around 55 pounds.
IowaCummins
