Cab fit in bed?
Cab fit in bed?
Postby ekk33 » Mon Jan 18, 2010 6:33 pm
Will a cab fit in the bed?
Considering buying a cab, and need to know if it is a transport option.
1992 W250
Cooler Tubz, PS Intercooler
Pump Mods,3200 Spring,
ekk33
Postby ekk33 » Wed Jan 20, 2010 6:52 pm
Anyone?
1992 W250
ekk33
Postby KTA » Wed Jan 20, 2010 7:01 pm
Just guessing but from the looks of it I would think it wouldn't fit between the wheel wells. I do think you could lay some 2X6's across the bed rails and put a sheet of 3/4" plywood on top of them and haul one easily on top of the bed. I think the bedsides would hold an empty cab weight just fine, but don't know that for sure so try at your own risk! LOL
Postby PRINCETON_JAKE » Wed Jan 20, 2010 9:15 pm
Im pretty sure it wont fit, you have to consider how far the firewall sticks out too.
1992 cummins, 2wd, A518, WH1c, 60mm,12cm housing, fuel screws maxxed, fuel pin turned and ground, 3200rpm spring, big Amsoil air filter, 4" stack, timming bumped, piston lift pump, Bosch 190's, 18" Maxxi Hulk rims, and Nitto Terra Grapplers.
PRINCETON_JAKE
Postby Richie O » Wed Jan 20, 2010 9:21 pm
I threw a junk one in a junk chevy once. I was a yard truck so dents were not a problem. :D
Postby BobS » Thu Jan 21, 2010 8:32 am
Since everybody misplaced their tape measure I'll give you the dimensions:
BED:
Inside rail to rail=66"
Inside height floor to top of inside rail=19-1/2"
Insider fender well height=13" (actually a bit over 12-1/2" but close enough)
Inside fender well to fender well=48"
Cab, stripped & bare:
At 19" (bed rail height) it is approximately 60" (+-1")
So if you throw a wooden pallet or two between the fender wells and set the cab in sideways on the pallet(s) with the cab floor hump positioned over the wheel well it should fit. I would use a thick pallet and throw a rug over the wheel well on the rear cab side to prevent the cabs back panel from rubbing and bouncing off the wheel well. Without the pallets you could end up with a dent in the rear of the new cab.
BobS
91.5 W250 NV4500 Conversion
89 D350 Stock
BobS
Postby Ace » Thu Jan 21, 2010 9:45 am
Bob, I think you got too much time on your hands! :P
Hey, on a side note: I know another Bob from Greene Co. - my cousin Bob. I'm pretty sure you're not him, but I'll bet you've seen him around. He's a Civil engineer for the State and works on the roads and bridges and stuff like that in the area. They have a big farm there, I've been to it only once about 7 years ago.
Postby BobS » Thu Jan 21, 2010 11:04 am
Ace wrote:Bob, I think you got too much time on your hands! :P
I took an early retirement due to health reasons. Now I'm just trying to keep beating the odds against me and stick around for a while. Anyhow, I'm generally willing to grab a measurement or help somebody in need from past experiences, weather permitting.
No, I'm not your cousin but I may consider being adopted! ;)
BobS
89 D350 Stock
BobS
Re: Cab fit in bed?
Postby burnt_servo » Thu Jan 21, 2010 2:57 pm
ekk33 wrote:Will a cab fit in the bed?
i work for a auto wreckers from time to time when i need parts .
the easiest way i've found to move boxes and cabs is ,
lay several 2x4's across the top of your box so they stick out over each side roughly 6 to 12 inches .
tie them all together ( ie nailing , screwing rope , use your imagination ) so they are spaced out evenly
then strap them down to the box tightly ( in between the box and the cab i run 2 heavy straps down to the frame ) .
then gently lay what ever your trying to transport on top and strap it down to the 2x4's .
'93 w250 .... stock ...
burnt_servo
Postby PToombs » Thu Jan 21, 2010 6:03 pm
I like Bob's idea, it's down in the bed and easier to tie down. ;)
