wheels spacers
Postby adam greene » Sun Jan 24, 2010 12:57 pm
how wide of a wheel spacer do you think i will need for 265s if i go with a half inch spacer will i need longer studs? whats the widest you can go without changing the studs?
adam greene
Postby adam greene » Tue Jan 26, 2010 3:24 pm
ok bought some wheel spacers now i cant find any 5/8 lug nuts to fit inside the spacer to tighten the spacer to the hub anyone else run into this problem
adam greene
Postby dpuckett » Tue Jan 26, 2010 6:19 pm
Most of us avoid spacers of any kind. Too much potential for things to go wrong.
DP
