WH1C vs. HX 35
WH1C vs. HX 35
Postby Moebiusgold » Mon Jan 25, 2010 7:07 pm
So, I bought a HX 35 off of buyer beware-bay and when it showed up, it was a WH1C instead. The seller says I could send it back. But then he claims that the thrust bearing is better on it then the HX series. I have not heard that claim before. I am more concerned that it limits me from upgrading to the 6 blade 60 mm compressor. I have to admit I was more after a wastegated turbine. I'm trying to get the low RPM smoke to go away and not trying to make big numbers. But then I wouldn't mind putting on a 6 blade 60 mm compressor housing (which can only happen on a HX) on it if that is not enough to clean it up. That is cheap enough. What does everyone think. Send it back or keep it? Pros and cons of either. Thanks
92 W350 DRW
Moebiusgold
Re: WH1C vs. HX 35
Postby peobryant » Tue Jan 26, 2010 8:08 am
Moebiusgold wrote:So, I bought a HX 35 off of buyer beware-bay and when it showed up, it was a WH1C instead. The seller says I could send it back. But then he claims that the thrust bearing is better on it then the HX series. I have not heard that claim before. I am more concerned that it limits me from upgrading to the 6 blade 60 mm compressor. I have to admit I was more after a wastegated turbine. I'm trying to get the low RPM smoke to go away and not trying to make big numbers. But then I wouldn't mind putting on a 6 blade 60 mm compressor housing (which can only happen on a HX) on it if that is not enough to clean it up. That is cheap enough. What does everyone think. Send it back or keep it? Pros and cons of either. Thanks
A WH1C is watsegated. From conversations in the past, I don't think there is really any difference between an HX35 and a WH1C. You could call HTT (or whoever you planned on getting the 60mm compressor upgrade from ) and see if it will work with a WH1C. If not, send it back, if it does work, just keep it.
Postby PToombs » Tue Jan 26, 2010 6:16 pm
I don't know about a WH1C, but I know you put a 60mm 6 blade on an H1C. I have one, from HTT.
U C?
Postby dpuckett » Tue Jan 26, 2010 6:26 pm
Clean and reset of the injectors may do more to eliminate smoke than a faster spooling turbo.
You can get a 60mm upgrade for the WH1C.
DP
Postby Tintacker » Tue Jan 26, 2010 7:47 pm
PToombs wrote:I don't know about a WH1C, but I know you put a 60mm 6 blade on an H1C. I have one, from HTT.
U C?
:lol: :lol: :jocolor: :lol: :lol: ..................That was pretty funny.
SOLD: :( '92 W250 LE auto PDR 190's, 3200 spring, Skyjacker 2" front springs with Bilstein 5100s
'01 2500 QC/SB 4X4 6sp, camper puller
Tintacker
