brake light
brake light
Postby stock91w350 » Fri Feb 05, 2010 7:36 am
well i unplugged the abd box and got rid of the abs light but the other brake light is still on, if i stap the brake pedal hard and fast it goes out till it is pushed down again normaly, about half way down it come back on.
91 w350 5spd dually. 5"stack, fuelpin, starwheel all in, smoke screw all in, homemade cold air intake
stock91w350
Re: brake light
Postby cougar » Sat Feb 13, 2010 11:01 am
Shuttle valve off center?
01 2500 "the work truck".
cougar
Re: brake light
Postby dpuckett » Wed Feb 17, 2010 12:09 pm
Shuttle valve? Never heard that one. Not to say it doesnt exist, it's just a new one on me. Either way before my time, or well after 93.
I'd think parking brake pedal not fully retracted, or low vacuum (though if your heat vents change as they should, and you have any sign of brake assist, I'd rule that one out).
You could remove the bulb, too.
Re: brake light
Postby PToombs » Wed Feb 17, 2010 6:42 pm
Dan, he means that silver widget below the master cylinder. I call it a proportioning valve, but that may be incorrect.
It sounds to me like that is the problem too. Equal brake pressure keeps the shuttle in the middle, and the light out. When you blow a line, the shuttle moves, and the light comes on. You sometimes have to bleed the opposite end to move it back and get the light to go out.
Or you can unhook the wire. ;)
Re: brake light
Postby Richie O » Wed Feb 17, 2010 6:51 pm
If it is that valve it won't flow fluid to all 4 corners. Usually a heavy stab on the pedal with the opposite bleeders open will make it come around.
Re: brake light
Postby stock91w350 » Thu Feb 18, 2010 7:53 pm
I uplugged the wire going into the parking brake but it still on.
stock91w350
Re: brake light
Postby stock91w350 » Thu Feb 18, 2010 7:54 pm
PToombs wrote:Dan, he means that silver widget below the master cylinder. I call it a proportioning valve, but that may be incorrect.
what wire do i unhook?
stock91w350
Re: brake light
Postby 2stroke » Thu Feb 18, 2010 8:01 pm
try unplugging the low vaccum switch.
91 non I/C w-350 SRW
2stroke
Re: brake light
Postby stock91w350 » Fri Feb 19, 2010 5:39 am
2stroke wrote:try unplugging the low vaccum switch.
where is that located?
stock91w350
Re: brake light
Postby 2stroke » Fri Feb 19, 2010 2:08 pm
driverside fender well. should have a single vaccum line comming out, and a single electrical connector.
2stroke
Re: brake light
Postby PToombs » Fri Feb 19, 2010 6:35 pm
I was talking about the wire on the valve below the master cylinder. There may be other issues causing the light to come on.
Re: brake light
Postby stock91w350 » Sat Feb 20, 2010 12:43 pm
2stroke wrote:driverside fender well. should have a single vaccum line comming out, and a single electrical connector.
I found it, unhooked the connector and light still on, maybe time to just take the bulb out, lol
stock91w350
Re: brake light
Postby stock91w350 » Sat Feb 20, 2010 12:46 pm
PToombs wrote:I was talking about the wire on the valve below the master cylinder. There may be other issues causing the light to come on.
how far below the master cylinder is it? couldent find it, anyone have a picture of it for me to see? thanks
stock91w350
Re: brake light
Postby dpuckett » Mon Feb 22, 2010 4:05 pm
On your 91, it's not below the master cyllinder- it's on the inner frame rail, driver's side.
Re: brake light
Postby PToombs » Mon Feb 22, 2010 7:12 pm
ah HA! :oops:
