ip leak
ip leak
Postby GeneralC » Sat Feb 20, 2010 8:28 pm
Guys i have a buddy with a 92 automatic and hes got a leak comin out of a tube that looks like a overflow on the right side of the afc. its a black rubber piece. i have a 91 and have never saw a piece like this. he just had a bully dog pinned installed and it started leakin as soon as it was installed. he had the guy who installed it take it back out and put the stock pin back in but it still leaks. my guess was maybe the diaphram was installed upside down ? im probably wrong but im not sure what that piece is on the ve. any ideas guys ? thanks
91' W250 metallic blue with a few go fast goodies... s362, 6X16's, airdog 150, dual disk, maxed pump with 3200 gov spring and M&H Stage III Pin.
GeneralC
Re: ip leak
Postby Richie O » Sat Feb 20, 2010 9:35 pm
GeneralC wrote:Guys i have a buddy with a 92 automatic and hes got a leak comin out of a tube that looks like a overflow on the right side of the afc. its a black rubber piece. i have a 91 and have never saw a piece like this. he just had a bully dog pinned installed and it started leakin as soon as it was installed. he had the guy who installed it take it back out and put the stock pin back in but it still leaks. my guess was maybe the diaphram was installed upside down ? im probably wrong but im not sure what that piece is on the ve. any ideas guys ? thanks
Its common for the afc to leak after a deeper fuel pin goes in. It causes the small pin that rides on it to come out further and sometimes that will make it develope a leak. The pump will need to come apart and get a new O ring seal.
Re: ip leak
Postby GeneralC » Sat Feb 20, 2010 10:50 pm
how far does the pump have to be tore down to replace the ring ? also exactly what does the o - ring do in the pump ? thanks for the reply man ! im trying to learn all i can lol
GeneralC
Re: ip leak
Postby IowaCummins » Sun Feb 21, 2010 12:27 am
if you follow the steps in the govenor spring replacement posts that is what you need to to. you have to remove the top half of the pump. then have to drive out the retaining steel balls that hold the afc levers pin in. i will find some threads on this
IowaCummins
Re: ip leak
Postby IowaCummins » Sun Feb 21, 2010 12:33 am
here you go. this is what you have to do to repair this leak.
http://dens-site.net/Dodge_CTD/Governor ... index.html this one is the first half to get you to the point of the next website begins at.
http://www.dieseltruckresource.com/dev/ ... l?t=153154
IowaCummins
Re: ip leak
Postby GeneralC » Sun Feb 21, 2010 2:04 pm
ok thanks for the help !
GeneralC
