Balancer Removal?
Balancer Removal?
Postby NOT_A_BLAZER » Wed Feb 17, 2010 9:25 pm
I'm working on my '91 Cummins, trying to fix the KDP but I've run into a roadblock....
I'm trying to remove the balancer,but the bolts won't budge! I even removed the radiator so I could get to it with the impact (which opened up a whole other can of worms) and only got one of the bolts to come out. Anyone else have any problems with this?
Nick
1991 D250 (5.9 CTD/727/D70) all stock (for the moment)
1987 D100 (225 Slant/904/8.25) future body donor for the '91
1979 Ramcharger (318/727/NP208/D44/9.25) Project Truck
NOT_A_BLAZER
Re: Balancer Removal?
Postby Richie O » Wed Feb 17, 2010 9:31 pm
I have only done 1 and they all came right out. I guess try pb plaster or something and be patient. You sure don't want to bust them.
Postby SNOOT » Wed Feb 17, 2010 9:46 pm
There should be a notch on the out side of the balancer. I put a round dowel from the notch to the cross member so it can not rotate. Use a breaker bar to get them loose and prevent the engine from spinning.
Make sure you use a 6 point impact socket to prevent rounding the bolt head.
1993 W350
SNOOT
Postby SNOOT » Wed Feb 17, 2010 9:48 pm
Also when your doing the KDP check the bolts behind the cam gear. Turning the enging over should get you access to all of them. I had 2 of the 3 hand tight.
1993 W350
SNOOT
Postby burnt_servo » Thu Feb 18, 2010 12:24 am
is it possible these where loctited in ?
if so maybe a bit of gentle heat will help things out .
'93 w250 .... stock ...
burnt_servo
Postby NOT_A_BLAZER » Sun Feb 21, 2010 5:46 pm
Well,I kept at it with the impact and eventually the rest of them came out,so I'm all set now.
Nick
NOT_A_BLAZER
Postby BobS » Mon Feb 22, 2010 5:45 am
Sometimes you have to rock the bolts out by changing directions on the impact wrench. Sometimes I use a 3# brass hammer to slug a box end wrench again using the rocking method. This gives a better feel of how tightly frozen the bolts are. Getting a bigger impact is some cases will work but you have a better chance of snapping the bolt off because it is not possible to actually judge the amount of torque that you are actually applying.
BobS
91.5 W250 NV4500 Conversion
89 D350 Stock
BobS
Postby NOT_A_BLAZER » Sun Feb 28, 2010 8:35 am
Got another dumb question,is there a certain way the balancer goes back on?
Nick
NOT_A_BLAZER
Postby IRoss » Sun Feb 28, 2010 9:59 am
When I did mine I had to have the engine locked (well,4-lo in first with blocks under the wheels) and I used a big cheater to get the leverage out from in front of the rad...a buddy underneath holding the socket tight doesn't hurt either....
91.5IC 4x4 5spd extra springs
valet, 190s, ,18cm, 4"ëxh.
H4 conversion w/relays
rwal mia w/prop. valve
IRoss
Postby PToombs » Sun Feb 28, 2010 6:32 pm
NOT_A_BLAZER wrote:Got another dumb question,is there a certain way the balancer goes back on?
Nope! Throw it on and away you go. :D I put a chisel in the notch on mine and braced it against the frame or something to loosen and tighten. I actually torqued mine when I put it back on.
I think I'm getting fussy in my old age. ;)
Postby TWorline » Sun Feb 28, 2010 8:16 pm
They only need to be torqued to 100 ft. lbs..
Tim Worline
http://www.CoolerTubz.com/
TWorline
Postby NOT_A_BLAZER » Sun Feb 28, 2010 10:35 pm
I'm sure this sounds stupid but which notches? There's some notches on the outer edge of the balancer,you're not talking about those are you?
Nick
NOT_A_BLAZER
Postby Richie O » Sun Feb 28, 2010 10:40 pm
Your 91 will not have the notch that Pete's 92 has. Only trucks with a crank position sensor has the notch. :D
Postby PToombs » Mon Mar 01, 2010 6:29 pm
Richie O wrote:Your 91 will not have the notch that Pete's 92 has. Only trucks with a crank position sensor has the notch. :D
Ah HA! :shock: I didn't know that, sorry to get you all excited N_A_B. :oops:
Postby NOT_A_BLAZER » Mon Mar 01, 2010 6:41 pm
I'll just have to bribe somebody with a six-pack to come and help me with the truck. :D
Nick
NOT_A_BLAZER
