PToombs wrote:That's not bad pressure. I used to have 15 to 16 at idle, about 11 at WOT. I think I scarfed the innards some because the inlet screen was plugged and the pressure is down a little. You should run a prefilter or screen of some type. I'm upgrading to a 1/2" suction line and a full size prefilter with a glass bottom so I can see contaminants.
Douglas wrote:hey-Hey!!!,
Could y'all tell me exactly which piston lift pump you have and where did it come from? Some further questions while I'm at it...since they ride on the cam, and likely have more pressure on their lifter. Does any special break-in need to happen? Rev-Lube on it? Any special mods to the fuel line hook-up?
cheers,
Douglas
