Towriggity wrote:Has a pretty heavily built tranny and a new torque convertor, however there have been times that it could not move a load with it floored in 4 hi, load was about 20 k
Towriggity wrote:Timing bump is pushing it to the head right? or is that too much?
1STGENFARMBOY wrote:If they didn't skip a tooth, whitch i dought cause it a little more involved that just
movin the pump, there should be a hash mark or a line cast in the pump flange where it mounts to the cover
at 9:00 oclock that are lined up with stock timming, when they say 1/8 in bump
that means move clockwise 1/8 in from the mark on the cover,![]()
Dar
