Not the hoss I had hoped for
Re: Not the hoss I had hoped for
Postby Towriggity » Thu Mar 04, 2010 11:20 am
Being as there is no spark to run a timing light, how exactly do you time one of these pigs?
93 w350 xcab,auto, bhaf, straight pipe, piston lift pump, pot od, afc lever removed, fuel screw to collar, cable kill
Towriggity
Postby Begle1 » Thu Mar 04, 2010 11:42 am
Either a specialty timing transducer, an arcane method with a dial indicator on the injection pump rotor, or by ear.
Postby Subliminal » Thu Mar 04, 2010 12:02 pm
I'm no expert, but I got about 1/2 a turn or less on my fuel pin before I hit the collar...that's really not much to turn up the power. Of course, 25 PSI is pretty good, so I dunno.
3200 RPM spring might help you.
Subliminal
Postby Towriggity » Thu Mar 04, 2010 3:01 pm
Mine took 3 turns to hit the collar, I'll get a pic of the Pump relative to the head, thanks for all the advice
Towriggity
Postby DZL_Damon » Thu Mar 04, 2010 4:40 pm
3 flats or 3 full, 360* turns? wow, that would be a LOT. Both of my non i/c pumps were about 1/2 turn or so.
Like Someone else said, a built tranny is all fine and dandy, but if they put a new, stock torque converter in, it will not matter how good the tranny is!!! Goerend, DTT, and Suncoast make the good torque converters. Hughes (?) makes an ok one for less money. There is plenty of power to be had, but you should get some gauges as mentioned.
-93 W350,CC, DRW, A518, Pump maxed, DDP3, DennyT, 4" DP, black muffler stack with flapper. HE351cw, CoolerTubz, PS I/C, 4601HP elec. fuel pump, 205k
-89 D250, clean utility bed, TF727, new IP, 76k
-09 VW TDI 2.0L CR, ~45mpg, 20k
DZL_Damon
Postby Towriggity » Thu Mar 04, 2010 5:06 pm
Here's how the pump sits in relation to the head
[Image
Towriggity
Postby Towriggity » Thu Mar 04, 2010 5:16 pm
Dzl-Damon, your sig is almost exactly what I have planned for mine, how do you like the setup, how much power, and is it useable? Thanks for the input too here's what I'm working with
Towriggity
Postby Towriggity » Thu Mar 04, 2010 5:19 pm
Take it easy on the bumper guys, built it outta scrap one weekend, it's not done yet. :shock:
Towriggity
Postby 1STGENFARMBOY » Thu Mar 04, 2010 6:06 pm
Bumper looks great to me, thats gona be an awsome truck, as my preacher
tells me THATS A MAN TRUCK. :lol: :lol:
Postby Towriggity » Thu Mar 04, 2010 6:36 pm
In regards to the picture of my pump, some people actually push the pump all the way to the head? Approximately how many degrees advanced is that over stock? Seems like a good way to toast a hg.
Towriggity
Postby JBradley500 » Sat Mar 06, 2010 11:12 am
what's the reason for a spring pulling on the throttle linkage that the throttle "opens"?
340hp/662tq (8/24/12)
JBradley500
Postby TWorline » Sat Mar 06, 2010 5:11 pm
JBradley500 wrote:what's the reason for a spring pulling on the throttle linkage that the throttle "opens"?
A lighter throttle pedal.
Tim Worline
http://www.CoolerTubz.com/
TWorline
Postby huntinguy » Sat Mar 06, 2010 5:26 pm
That's all good untell the other spring breaks and your truck takes off on you. :shock: Then you could call it a toyota. :lol:
89 non-I/C W-250, flatbed. 4" turbo back. Ground fuel pin, AFC tuning.
huntinguy
Postby TWorline » Sat Mar 06, 2010 5:31 pm
I'm guessin' it would be called alot of other things before toyota!:mrgreen:
Tim Worline
TWorline
Postby 1STGENFARMBOY » Sat Mar 06, 2010 6:05 pm
What's up with the zipties on the dipstick. :shock: ROSCO P. COALTRAIN :lol:
