Roadtrip Checklist?
Roadtrip Checklist?
Postby pulltilbroke » Thu Mar 11, 2010 1:03 am
Well looks like my old pile of junk is goin on a fairly long roadtrip (1500 miles) to go possibly drop off some parts for a board member then goin to pick up a garden tractor and front axle for the 60K10.
Is there any thing other than the usual I should check on a 350,000 mile truck before I'm east bound and down?
BTW I'm goin to Peru IN then down to Louisville KY then up through ST Louis MO and home from there.:cool:
The usual consists of
1. Fresh oil change
2. Change or top off lube in the tranny, t-case and diffs
3. Valves have been set
4. Wheel bearings were inspected and packed in early December
5. Brakes all look good
6. Turn the fuel down a smidge for mileage[duhhh]
I will have tools, a spare belt and tensioner and fuel filter, an assortment of jumper wires, oils, coolant, and a multi meter a carton of smokes, duct tape, and bailing wire.
Feel free to add as you see fit
Re: Roadtrip Checklist?
Postby oldestof11 » Thu Mar 11, 2010 3:10 am
U-joints!
Postby pulltilbroke » Thu Mar 11, 2010 3:31 am
Yep, planned on it, might toss the spare shaft in to.
Postby Richie O » Thu Mar 11, 2010 9:19 am
I always worry about the " turney " stuff on the engine. A alternator and water pump too if you have them. I have had both of those seize and rip the belt off. :roll: Being a standard I would not worry about a spare starter.
Postby RumbleFish » Thu Mar 11, 2010 1:10 pm
check the throttle linkage on the pump. when i got my 1st 1stgen, i noticed the linkage looked weak and thought i should replace it. it broke on my 1st semi-long distance trip.
Postby pulltilbroke » Thu Mar 11, 2010 2:04 pm
The alt is fairly new, but I supose I could toss a spare pump in, I just rebuilt the starter last fall so it should be good to go. the linkage looks real good too, I picked up a real good one from Mark when I switched over to the I/C bracketry.
I also got a spare volt reg behind the seat.
Postby 1STGENFARMBOY » Thu Mar 11, 2010 2:21 pm
I don't mean to poop on your ider of beeing prepaired but if you took a spare everything but
one thing thats what would break, just check things over and go. I took a trip out west in 2002
with my family we were gone 32 days and went 11,050 miles in a brand new jeep cherokee 60th
aniversery it had 7,000 miles when we left, it broke down 2 times one time the aircondition comp
locked up and then in yellowstone smoke started rollin out from under the dash :shock: :shock:
but we made it back home fine and still it was the trip of a lifetime. :)
Postby 1STGENFARMBOY » Thu Mar 11, 2010 2:23 pm
If somthin happins anywhere around southern il call me and i will be glad to
come up and help you get fixed, i'll pm you my number.
Dar
Postby pulltilbroke » Thu Mar 11, 2010 3:08 pm
Thanks for the offer.
I just like to try to be self sufficient if somthing does happen.
Postby 1STGENFARMBOY » Thu Mar 11, 2010 3:29 pm
give your hoses a look for
bulges and such. wiggle your fan cluch, windshield wipers? headlights,breaklights, the two
most important lights no dought, well for you,--- mine is the light in my EGT gauge for nightime
driven. :roll: tire PSI. I would still give those wheel bearings a quick jiggle.
Postby pulltilbroke » Thu Mar 11, 2010 3:44 pm
Wipers were new in December, I'll check the fan clutch. Had the front end apart a few weeks ago it all looks good, tires are decent and will check pressures when I leave, 07 date on the tires. Light will get inspected before we leave and at fuel stops.
Postby 91cumminsd250 » Thu Mar 11, 2010 7:40 pm
Fire Extinguisher?? :) oh and the carton of smokes fixes all
D250, Diamond Eye 4" exhaust, Denny T Stage 2 pin, Homemade intake, Boost/Egt gauges, too many window stickers
91cumminsd250
Postby pulltilbroke » Thu Mar 11, 2010 8:17 pm
I always have a fire extinguisher behind the seat. :D
Postby Douglas » Fri Mar 12, 2010 5:25 am
hey-Hey!!!,
There is no way to be prepared for all failures...:) Even so, some things don't take up much room at all, for instance a list of Cummins parts suppliers along the way. That and a AAA package that will tow you some distance would cover the big stuff. You've listed the big stuff already, perhaps add a bit of hand cleaning supplies. Ov course you realize that carrying a big pile of spares increases the likehood of a failure...heh-heh-heh. Anyway, looking forward to hearing you needed none of it.
On 'things to check', examine water/acid level in your battery(s). Seems my flooded-cell ones are always low, but sealed sorts like Optima don't have this issue.
cheers,
Douglas
1991 D250, 727 and 16cm H1C.
Douglas
Postby Remps » Fri Mar 12, 2010 9:49 am
Make sure you got a flashlight with a good battery. I keep a hat in the truck with the little LED lights built in to the brim, that thing is super handy. I also keep a 6 volt LED flashlight in the truck so I can save the hat battery for when I might really need it.
