Any tricks to get open diff to hook?
Postby bgilbert » Sun Jul 15, 2007 7:52 pm
Where can I get a 'full spool'? I didn't see one on Randy's ring and pinion site, only a 'mini-spool'.
Postby wannadiesel » Mon Jul 16, 2007 4:55 pm
The Pow'r Lok diff in our trucks is called that because the more power you apply, the tighter it clamps the clutch packs.
If your dad's is dragging in turns, dump a bottle of limited slip additive into the rear.
Best dyno: 408/844
wannadiesel
diesel guru
Postby 90firstgen » Mon Jul 16, 2007 10:28 pm
wannadiesel wrote:If your dad's is dragging in turns, dump a bottle of limited slip additive into the rear.
I thought about that. It's just straight royal purple gear lube right now I believe. Thanks Dave
1990 2x4, 3/4 ton, Getrag, Cummins N/I
3200 Spring
Full Fuel Screw maxed (+/- 4 turns)
Injector rebuild with bigger nozzles
1/8" Timing bump
Airflo Intake
HTT 56mm Compressor
14cm Wastegated Housing
Stan's 4"
90firstgen
Postby JQmile » Wed Dec 12, 2007 5:01 pm
If you're at the strip, just get some slicks. They'll hook about 100% better even if it is an open diff.
JQmile
Postby bgilbert » Wed Dec 12, 2007 5:09 pm
I've got a Detroit Locker now 8) .
Postby ford69557ci » Wed Dec 12, 2007 5:46 pm
i just filled my diff full of .035 mig wire lol way better than a locker
ford69557ci
Postby PToombs » Wed Dec 12, 2007 6:27 pm
How does everything go roundy round with it full of wire? :scratch:
I did that once on a Duster, didn't last long! :thatsucks: :dayum:
:jumpsmile:
Postby flashgordon » Wed Dec 12, 2007 10:01 pm
PToombs wrote:How does everything go roundy round with it full of wire? :scratch:
:jumpsmile:
Must have been the little old 7 1/4" that never had a posse option, and came with such high HP eng as the slant six and some 318 :lol:
flashgordon
Postby PToombs » Thu Dec 13, 2007 4:41 pm
Pulled the 6 and crossmember, put in a 340. Built the trans up, couple trick parts. I drove it for almost a week, then crunch, grind, clunk clunk clunk! I did get it to go 1 more mile towards home though. Then I pulled the 8.75 out of a van and put in. It grabbed good, but looked like a frog! :alien: The wheels stuck half way out of the wells! ;)
Postby MMiller » Thu Dec 13, 2007 7:12 pm
bgilbert wrote:I've got a Detroit Locker now 8) .
It took you a while to listen to me, huh.....  Now, who you going to get to install it?  Are you bringing it out this weekend for me to do? :lol:   Did you get a good buy?  You surely didn't shell out for a new one, I know you better then that.... :shock:  Call me...I've got some questions for you.Michael
MMiller
Postby flashgordon » Thu Dec 13, 2007 8:44 pm
PToombs wrote:Pulled the 6 and crossmember, put in a 340. Built the trans up, couple trick parts. I drove it for almost a week, then crunch, grind, clunk clunk clunk! I did get it to go 1 more mile towards home though. Then I pulled the 8.75 out of a van and put in. It grabbed good, but looked like a frog! :alien: The wheels stuck half way out of the wells! ;)
Yeah, I'd like to find a dart demon, for cheap, that i could hack up and make a race car out of.................Just don't have the hart to do it to my Cuda. ;)
Flash.
flashgordon
Postby bgilbert » Fri Dec 14, 2007 8:26 am
Paid $550 shipped for a Dana 70HD (35 spline shafts) with the Detroit already installed. Oh and it came with SHOT wheel bearings and races :roll: :roll: :bh: .
Now you know my number and can call it anytime. Bill.
Postby seeker1056 » Fri Dec 14, 2007 9:21 am
what is the difference between the various pumps ie 114, 205 etc?
Different years, applications, ???
Is one better than another to start out with for modifyin?
Thanx
Sponsors of new truck
Performance Diesel Injection
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
Postby PToombs » Fri Dec 14, 2007 6:10 pm
bgilbert wrote:Paid $550 shipped for a Dana 70HD (35 spline shafts) with the Detroit already installed.
Shipped! :shock: That's funny right there! :mrgreen: Delivered is more like it! :lol: :jumpsmile:
Postby ford69557ci » Sun Dec 16, 2007 12:09 pm
well the tires chirp a little on tight corners but i have had no problems and its been like that for almost year now. i weld the diff up in about every hot rod i have owned and i have never broke one
ford69557ci
Return to Competition
