lectro_static wrote:Yours is the one on youtube that whistles so nicely? Are you controlling it, if so how? What is the appx start setting on it,(about how far closed)?
Mine doesnt seem to "sing" as well as yours, altho I have not tried it with the aircleaner off. I have not heard it bark yet but would think it would if I snap off the throttle? Is there any way to tell if I am over spooling it? I do not have a drive pressure gauge. I THINK Im on the right track with tuning it, Im not sure it will do exactly what I was hoping, which is boost right off idle but less then 5lbs at crusing speed/light throttle.
I just closed it up a bit more and will try it out when I go out at lunch. I hope all Im asking/saying makes sense
93oilburner wrote:going to attempt the same swap on my 93 auto truck. Did the oil feed lines fit from the stock turbo? I'm running straight wmo and the temps and smoke are up! I have 40hp sticks and a denny T pin and a P/S cooler hoping this will cool it down. Any advise will help thanks.
DieselSharker wrote:Glad to hear it worked out for you. I was planning on doing this on a non-intercooled truck with a very goofy-looking crossover pipe sometime in the future if the 60mm upgrade doesn't work well for me so I may be picking your brain at a later date.
