dyno numbers
Re: dyno numbers
Postby PToombs » Wed Apr 28, 2010 5:24 pm
Andy, I've heard the same about the Stage IV. I know my EGT's go thru the roof after 3k rpms. It must be out of the map range, time for twins! :mrgreen:
Re: dyno numbers
Postby pulltilbroke » Wed Apr 28, 2010 5:40 pm
Pete, the thing is I'm only pushing 35psi which I know is at about the peak of its efficiency range. My egts only got to about 1550 which in any sledpullers mind is fairly cool yet :shock:
As for twins that would put me in a whole other league when it comes to pulling and I just don't have the coin to put a set together right now.
Re: dyno numbers
Postby PToombs » Wed Apr 28, 2010 6:27 pm
Only 35? :lol: I'm pushing 42-44 when I'm all into it. When I hit 3k it's 1200* and the pyro and tach go up together almost 1-1. At 3500 it's 1600*, and that's unloaded.
Re: dyno numbers
Postby pulltilbroke » Wed Apr 28, 2010 7:27 pm
On the street it will blast up to 35 then creep to about 40. I've seen low boost and egt's since I put the 2nd gen cooler in but with the same seat of the pants feel.
Re: dyno numbers
Postby SNOOT » Wed Apr 28, 2010 7:43 pm
You have an automatic ?
pulltilbroke wrote:Image
1993 W350
SNOOT
Re: dyno numbers
Postby gear jammer 91" » Wed Apr 28, 2010 8:19 pm
Driving really nice, I could average 18MPG on my commute to work. It's mostly highway and that was with two stroke oil mixed in. Somewhere I posted about my EGT's before and after the super 40. I could hit 40psi and pop a head gasket on command when the engine was cold. :yuck: The one benefit of the super 40 over a hybrid, is that it has a larger exhaust wheel, and a 4" outlet to help keep your drive pressure and egt's down.
I could be talking out my arse hear, but I really think I'm right. :finger:
01 LB7
gear jammer 91"
Re: dyno numbers
Postby pulltilbroke » Wed Apr 28, 2010 8:39 pm
Lance, I have an NV4500
Gearjammer, that makes sense, you wouldn't happen to know the minor and major diameter of the exhaust wheels on a H1c and a super 40 would ya?
Re: dyno numbers
Postby gear jammer 91" » Wed Apr 28, 2010 9:12 pm
pulltilbroke wrote:Gearjammer, that makes sense, you wouldn't happen to know the minor and major diameter of the exhaust wheels on a H1c and a super 40 would ya?
I barely grajitated hi scool, I don't have a clue. :mrgreen:
01 LB7
gear jammer 91"
Re: dyno numbers
Postby SNOOT » Wed Apr 28, 2010 9:18 pm
pulltilbroke wrote:Lance, I have an NV4500
That graph is weird the way it jumps up and down during your run. I suppose if all the other trucks have similar results its fine. When I was running my stock trans auto we related that to the clutches grabbing and then letting loose as the converter flashed.
Just found it interesting.
1993 W350
SNOOT
Re: dyno numbers
Postby pulltilbroke » Wed Apr 28, 2010 9:23 pm
Yeah, me too :oops:
Anyone else know?
Re: dyno numbers
Postby pulltilbroke » Wed Apr 28, 2010 9:26 pm
All the graphs looked like that sticks and autos. I don't know what the deal was.
Re: dyno numbers
Postby gear jammer 91" » Wed Apr 28, 2010 9:48 pm
I did some research and the "ideal" hx 40, which is what mine should of been, is supposed to be 60/65/16. http://www.htturbo.com/MatchingHighTechTurbos.pdf There's some info here on drive pressure and stuff.
I'm still looking for the number on the H1C.
it looks like the H1C is a 50/60/-whatever size exhaust housing you are running.
01 LB7
gear jammer 91"
Re: dyno numbers
Postby pulltilbroke » Wed Apr 28, 2010 10:07 pm
So mine is technicly a 60/60/16?
Re: dyno numbers
Postby gear jammer 91" » Wed Apr 28, 2010 10:12 pm
pulltilbroke wrote:So mine is technicly a 60/60/16?
That's how I understand it. So your only down 5mm on the exhaust side. It doesn't sound like much, but it could be causing high drive pressure and holding you back.
I like it when it sounds like I know what I'm talking about. :lol:
01 LB7
gear jammer 91"
Re: dyno numbers
Postby pulltilbroke » Wed Apr 28, 2010 10:17 pm
Sounds like i might have to plumb in a drive pressure guage. A 100psi guage should be enough right?
Return to Competition
