How to make a valet switch?
Re: How to make a valet switch?
Postby jwatso8 » Sat Jul 17, 2010 1:12 am
stupid question, but what the point of having a valet switch? what does it do? is it to cut off boost to the AFC, to get more smoke? thanks
SOLD 92 D250 intake,S300,coolertubz,i/p MAXED,366 spring,Dennyt fuel pin,DDP 4,airdog 100,gauges, 4" d/p w/5" stacks
TRADED IN07 2500 6speed,intake,CFM+,Edge EZ chip,MBRP exhaust,B&W hitch
NEW 2010 3500 6.7L DRW 4x4 CrewCab 4.10 grears
jwatso8
Postby Richie O » Sat Jul 17, 2010 8:15 am
jwatso8 wrote:stupid question, but what the point of having a valet switch? what does it do? is it to cut off boost to the AFC, to get more smoke? thanks
If you cut boost to the afc then the fuel pin does not push down which in turn will not add more fuel. It will take away 10 or more psi worth of fuel. Good for towing so things don't get as hot and also good if other people drive the truck. :D
Postby cougar » Sat Jul 17, 2010 8:17 am
By not allowing the fuel pin to move, you reduce/limit fuel.
01 2500 "the work truck".
cougar
