unixcowboy wrote:I cut 2 1/2 turns and bent the remaining 1/2 turn to form the hook that's needed to connect it.
I can run up to ~ 3500 real quick then it starts defueling but the engine still pulls to 3900.
Based on my speedo with the TC locked - my tach went south about 6 mos ago and hasn't been replaced yet.
soggy wrote:I cut two turns out and ran it up to 124 mph and it was still pulling, I had to let out because of egts. With 265/75/16 tires, 3.55 gear ratio and .069 OD ratio that puts me at 3230 rpms without accounting for TC slippage.
fatty wrote:soggy wrote:I cut two turns out and ran it up to 124 mph and it was still pulling, I had to let out because of egts. With 265/75/16 tires, 3.55 gear ratio and .069 OD ratio that puts me at 3230 rpms without accounting for TC slippage.
124 mph in a rattly old first gen?!![]()
You must be insane!!
mhuppertz wrote:fatty wrote:soggy wrote:I cut two turns out and ran it up to 124 mph and it was still pulling, I had to let out because of egts. With 265/75/16 tires, 3.55 gear ratio and .069 OD ratio that puts me at 3230 rpms without accounting for TC slippage.
I'm melting pistons at 120.
fatty wrote:That looks like you floated the valves to me.
oldestof11 wrote:I can see what fatty is saying, thought I disagree. Look at the 3 O'Clock position. Looks kinda like a sun-dial.
