How can you get a 1st gen to squeek into the low 20mpg?
Postby Begle1 » Wed Aug 01, 2007 4:18 pm
I'm amazed I lasted as long as I did after this thread...
I don't really have the inspiration to rile up as much trouble over there as I could.
Need to pretend to be an Asian pornstar or something next time...
Postby wannadiesel » Thu Aug 02, 2007 2:35 pm
Begle1 wrote:I'm amazed I lasted as long as I did after this thread...
You were so careful for so long and then you screwed up.
You won't even get through the door as a pornstar of any race. :roll:
Best dyno: 408/844
wannadiesel
diesel guru
Postby Begle1 » Thu Aug 02, 2007 6:37 pm
Well, I wouldn't start initially by saying that I'm a pornstar. I'd like, pretend I have a third gen, and post a few threads about getting stains out of the leather, asking how to fold the seats all the way back, wondering if there was a way to keep fog off the inside of the windows... Then after a week of asking random stuff like that I'd post a "thank you" thread, and get a couple of my buddies to pose in a third gen in quasi-homoerotic poses so everybody could get a glimpse of my work. And then everybody would wonder "is he making gay porno movies in a Dodge", and I'd follow up by posting some Cummins Erotica, and everybody would finally understand that the name "Lee G. Bee" is "Begle" backwards, and good fun would be had by all...
The hour was late and the Cummins purring along every inch of the haul. The signs forsaw the struggle of the climb as we neared the pass; the Cummins acted as though it was ready for the grade; breathing through enlarged exhaust and turbo, it anticipated any exertion. I myself was nervous; it was my first time, never before being behind the Cummins; the buckets held me firmly, yet gently; the heat of the engine poured as liquid over my face and legs; the noise smoothingly drowned out the outside wind; the gauges coyly shone their light into my eyes, every sweep of their lights and arms indicating that they were ready for my action.
My mind cleared as I soothed off the cruise control, intent on feeling every moment of the climb; I began by slowly brushing the throttle, which responded with a whispered squeal against my movement; as if to contradict my concern, the engine was nigh-imperceptible in it's response, but a note from deep within its lubricated inner workings implied that it too was anxious over releasing something it rarely had been able to display.
The grade began and I inhaled in time with the slowly, confidently arching boost gauge; the engine purred through the stacks close to my ears, responding in parallel to the mountain's stimulation; I could feel it's vibration through the wind, and the steady, delicate reciprocation's of heated air began to quicken against my flesh. In my last moment of anxiety I glanced around us: the silver-lit highway was ours alone; it was the last time that night I would be distracted.
After bare moments of sudden exhilaration the tone of the engine had wavered; still strong and steady, the Cummins' echos through the canyon came to my ears in increasingly louder, deeper, quaking and resonant vibrations that tremmeled through my mind, and the pedal quivered my body through my foot. I slowly, inconfidently, moved for the transmission lever; but the sliding whine of the gearbox below me seemed inadequately satisfied. Ever smooth upon the asphalt, the Cummins' tempo was slowing due to my own indecision; the lights glaring upon my eyes confirmed that it was ready for my push, discretely begging for a greater output of power. I moved my hand back to my grip on the wheel; tonight was a time for release; the engine's limits of endurance and ability beckoned for my demands. My foot pushed harder and deeper into the floor; the engine approvingly appealed for mercy.
The Cummins, still composed, dictated its pleasure with a screaming turbine, burning and crying within the bowels of the growling engine. The heat of the high pressure and fuel cascaded through the valves, swelling the cylinders and burning hotter, faster and longer; waiting to crack a head and wanting to continue, the engine was in my power. The agonizing heat and noise blissfully united us, my left hand found a switch, and firmly pushed on the water injection; fluid flowed into the engine, glistening over it's rigid ports and valves and entering six pumping cylinders, cooling the fires while elongating the bliss. The pyrometer found a steady rate of increase; the engine ached with power, straining with every stroke against the brutally rigid motor mounts, struggling for a passionate release; the engine screamed with torque, thrashing against the torque converter; but it was too tight for an easy escape; the fluids within swirled, pushed and transferred the power and anguish to the road, propelling us through the night faster and faster and faster.
Postby wannadiesel » Fri Aug 03, 2007 6:12 pm
:lol: You ain't right in the head, boy. :lol:
Best dyno: 408/844
wannadiesel
diesel guru
Postby MikeThomas » Sat Aug 04, 2007 1:44 pm
Hmmm, begle, must be lonely where you are at... :lol:
1993 W250, 5SPD, ne370's, HTT STAGE IV/14wg, DennT Pin, BHAF, P-PUMP, PUMP TWEEKS, 4" EXHAUST, 366
MikeThomas
Postby PToombs » Sat Aug 04, 2007 5:42 pm
MikeThomas wrote:Hmmm, begle, must be lonely where you are at... :lol:
Oh! Please don't get him started on the dearth of women in his life! :roll:
:lol: :lol:
Postby dpuckett » Mon Aug 20, 2007 3:16 pm
Ok, now that we have covered Begle's personal life, and being banned from DTR (?), back to the topic at hand (I'm so glad we can be ourselves in this forum).
No one has mentioned injector condition or timing. These can have a great impact on MPGs as well as what your pump is doing internally. I think 1.5-1.6mm of timing (stock injectors or pop pressures, anyway), combined with cleaning and recalibration of your injectors cant hurt. What are you getting for MPGs now? The stock auto robs you of 2-4mpg, though I got a consistent 22-23 with Mom's 92 back in 2000.
Daniel
Postby Firstgenfanatic » Mon Aug 20, 2007 7:07 pm
At this time I seem to be pulling 18mpg on the highway
93' Ram 250 club cab 4x4
*1993 Dodge Ram W250 club cab*, mild performance built A518, Hughes Converter, turned-up VE w/timing bump, tow package, 16x7 Alcoa wheels, M&H "M5" fuel pin, 366 gov spring, 4" exhaust, 16cm turbine housing, cold air intake, Isspro pyro/trans/tach/boost, KDP secured
Firstgenfanatic
Postby mhuppertz » Tue Aug 21, 2007 7:40 pm
First, the guy did mention that he has a 4x4, and believe me 20mpg is possible, but not at all easy.
Second, did you really get booted from DTR Begle? I looked at the post you referenced and didn't get the joke. I'd like to though.... but I gotta tell you, that devious porn star trojan horse made me about fall out of the chair!
mhuppertz
Postby mhuppertz » Thu Aug 23, 2007 6:49 pm
I just got 19.64 MPG combined by changing to an electric fan.
mhuppertz
Postby Begle1 » Thu Aug 23, 2007 7:01 pm
You really missed my ban-nation from DTR a year or so ago?
That makes me feel insignificant...
Postby GLHS » Thu Aug 23, 2007 10:22 pm
Non intercooled 2wd auto or stick will usually break 20+ all year long. Start adding up wieght from ext. cabs, 4x4s, 4:10 ratios and it goes south.
How about 85 psi in all the tires? :D
GLHS
Postby meby » Sat Aug 25, 2007 12:47 pm
my paw has a 90' reg cab 5 spd 3:55 gearing bone stock truck. when he drives it he gets 21-23 mpg with an all time high of 25mpg once. When I drove it I got 19-20 mpg, wonder why? :twisted:
-1991 D-250 bone stock
-1997 Civic Hatchback
-Case 530 CK
-Speedex Walking Tractor.
-BCS Walking Tractor
www.ebyfarmsllc.com
meby
Postby PToombs » Sat Aug 25, 2007 4:30 pm
Right leg 2 inches longer than the left? :lol:
Seriously though, I see this same thing here. My wife can get 2 mpg more out of the Jeep than I can. I take off harder, most of the time.
Postby mhuppertz » Sat Aug 25, 2007 10:13 pm
Begle1 wrote:You really missed my ban-nation from DTR a year or so ago?
I sometimes miss the important stuff.... sorry. I will look it up to try to get caught up.
mhuppertz
