Mark Burris, 93 Dodge pulling truck video
Postby bgilbert » Sat Sep 04, 2010 10:44 pm
Here's one of the top 1st gen pullers in the country guys: http://www.youtube.com/watch?v=0K0mZyETwPk
Left the line at 5900 rpm. Near the end of the pull he broke the throttle shaft off at the injection pump. Went from lotsa rpm to idle. The np205 is no longer under it. He's gone to a 241dhd and 5.13 gears. I tried to get him to go to the 271 but a 241 fell into his lap for cheap.
Also here's my gasser trash pull for the Dodge gasser truck fans: http://www.youtube.com/watch?v=F8G-BFuPERc
Feel free to look at my other vids on youtube, I've got a few other vids of my hooks and a few other Dodge gassers for those interested.
Bill Gilbert
Re: Mark Burris, 93 Dodge pulling truck video
Postby redneckroot » Mon Sep 06, 2010 7:27 pm
that first one is sweet whats he have for the rest of his running gear?
redneckroot
Postby bgilbert » Tue Sep 07, 2010 1:10 pm
redneckroot wrote:that first one is sweet whats he have for the rest of his running gear?
Dana 60, nv4500, np241dhd, and Dana 80. He's going to dual wheels in the rear for more bite :shock: .
Postby redneckroot » Tue Sep 07, 2010 6:27 pm
He running a ford dana 60 or a 2nd gen with some work? It is a nice looking truck.
redneckroot
Postby bgilbert » Wed Sep 08, 2010 2:30 pm
redneckroot wrote:He running a ford dana 60 or a 2nd gen with some work? It is a nice looking truck.
It's a 1st gen Dana 60 original 93 unit. With many upgrades of course. He kept breaking the passenger side 35 spline premium Warn lockout. Now the passenger side has a drive flange or slug and the driver side has a 35 spline lockout. Full spool in the front and in the rear I believe, if not the rear has a Detroit. I don't think you'll have any issues with the original Dana 60. The Nebraska boys are still using them as well. Most likely you'll need to upgrade to 35 spline 1.5" outers and lockouts though.
How bout you Andrew, do you still have the stock outers?
Postby pulltilbroke » Wed Sep 15, 2010 6:20 pm
Suprisingly yes, I am still running the stock 30 spl outers, open diffs and stock 3.55 gearing. Jeff, Curt, and Brian Banghart are running 35spl outers and are locked up all around and have swapped gears to correct the crawl ratio.
I will run the stockers til one goes bang and then I'll upgrade to the biguns.
Postby dazedandconfused » Fri Oct 08, 2010 8:58 am
Is that 1st truck p-pumped?
Return to Competition
